Joe90k
Speed doesn't Kill!
- Joined
- Apr 19, 2009
- Messages
- 226
- Reaction score
- 3
- Points
- 18
As the title says, last night I was fitting a new steering wheel control module, I thought it was compatible with my car but it turns out it had no where to plug in my steering angle sensor.
After fitting it some of the functions worked including the Multifunction working as I had hoped but the cruise control wouldnt work and also obviously VCDS could not talk to the steering angle sensor causing a lot of problems.
Now i have swapped back to my original for temporary while I order a new steering wheel control module but the error is still there. The error is in the Steering Assist Module of VCDS. It gives no details on the error but says G85 Steering Angle Sensor.
Any Ideas what this could be? Has the sensor been damaged perhaps?
TIA
Joe
TIA
Joe
