Monster MotorsportChris Nott
    May 2009
    SE London
    225
    How do I remove the speedo?
    how do i remove the speedo and when i plug it back in will i need anything reset.
    got a fly in there so just want to try and get it out
    thanks
    Khufu's Avatar
    West coast of Scotland
    5,693
    you release the colum adjuster and pull wheel out & down. Then the bit of trim directly below the cluster pulls out towards you, this will reveal 2 bolts to be removed. After removing these you will have to wiggle it out & release the connector at the back.
    I reckon all you will have to adjust is the time, a short drive should put the other lights out. Recoding is only needed done if you change the cluster, then you will need to reset steering moduless & brakes etc.
