Volks AutosMonster Motorsport
    Jan 2009
    234
    Valve springs replacement - Audi TSB
    I have found some info on the net, saying that for some cars (S3, cupra, Ed30) the valve springs need to be replaced (FOC under warranty). I have some text and the TSB (Tech. Service Bulletin) number but I can't find the official document anywhere. Of course the dealer couldn't find it...
    TSB 2019062/1 Symptoms are misfiring between 6000-6500 RPM's under heavy load accompanied by power surging.
    Technische Produktinformation
    Vorgangs-Nr.: 2018868/3
    Verbrennungsaussetzer bei hoher Drehzahl - 2.0 TFSI im Audi TTS und S3
    Freigabedatum: 19.02.2009
    P0303 - Zyl.3 Verbrennungsaussetzer erkannt (zu 80% werden auf diesen Zylinder die Aussetzer eingetragen)
    Fixing the valve floating and misfiring issues for free sounds great to me
    Khufu's Avatar
    West coast of Scotland
    5,693
    Haven't heard about recall, I know people have had misfires but usually after a remap.
    Jan 2009
    234
    It's a bulletin, not a recall. It's supposed to be used by a service centre when the symptoms exist. Here is an example with spring replacement in a TTS
    Johnnyb's Avatar
    Jul 2007
    725
    Was this not just a problem on the 08 S3 models? i thought the newer 09 models had stiffer springs?
    Jan 2009
    234
    If I am not mistaken the wrong springs were used between June (or July) 2007 and mid October 2008. Then they returned to the older type.
    Jan 2009
    234
    Anyone who has Elsawin?
