Chris NottSky Insurance
Results 1 to 17 of 17
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,852
    A3 2.0 TDI ''' TURBO'''
    Got this code yesterday and car went into limp mode.
    It happened when i was doing about 50-60 mph and put my foot down
    After switching car off then i restarted it and it was ok,never had the problem over the next 35 miles of driving.
    Thort id post it on here as ive had this issue before,but not very often only once say every 2 months of driving.........is it common/normal ( i use the car once a week) on this occasion i used it after 2 weeks.
    16618-boost pressure limit exceeded ( overboost condition) PO234-000-
    Full leather/19"wheels/cruise/
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    933
    Might be a problem with your turbo mate. I'd get it checked asap.
    VCDS USER
    May 2009
    West Yorkshire
    1,609
    This maybe unrelated to your limp mode problems but my car did this twice the other week while driving down the local bypass, the car would not go over 60mph, as i say, twice this happened, turned the car off and back on again and all was fine, however last week the turbo went bang.. The error message which had been stored on my ECU was 'boost pressure limit exceeded'.
    Audi A3 2.0L TDI S-Line Sportback
    waqi's Avatar
    Apr 2009
    Yorkshire
    150
    I had a similar problem, check all turbo related pipes for any pressure leaks
    devonmikeyboy's Avatar
    As far from JBS as possible !
    Feb 2007
    1,257
    Your turbo over boosted for some reason which could be down to many many different reasons. Try and put the car on VAG COM just for the safe side but if it doesn`t happen again i wouldn`t worry to much about it.
    06 Audi 2.0 PD140 Sport TDI Quattro S-LINE.
    Old engine 330 bhp @ flywheel 263 bhp @ wheel 490 lb torque. Audidriver write up HERE
    Now stripped and playing with an uprated Cryo treated engine fitted with bigger turbo,water/methanol,uprated injectors etc etc.Wanting 400 bhp and 500 lb torque.
    Other car 500+ bhp MK4 Golf R32 turbo.
    vw754's Avatar
    Nov 2006
    U.K
    1,852
    happened twice in 3 months of driving it, never happened on a 200 mile journey a few weeks ago
    Jul 2008
    33
    Turbo linkages getting sticky will cause this fault. You can check them with a vacuum pump which will gradually pull the linkage from one extreme to the other. It should operate very smoothly without sticking. I've replaced many for this problem.
    I have a new genuine Audi turbo, with the oil feed pipe and gaskets you need, for sale if any of you are interested. It's the latest supersession from the factory.
    Mar 2008
    Bradford, WY
    788
    first of all check intercooler pipes and turbo pipes, if not a common fault on these is the boost regulator sensor, take it out and clean it with some brake cleaner stuff! plug back in and should be ok.
    A3 2.0 TDI Optics Black S-Line, FR&RTuning Stage 3! GT20 Hybrid Turbo, THS TFSI FMIC, Sachs performance clutch kit+SMF, Milltek 2.5" Turbo-Back Non-Res Exhaust, ITG Maxogen Induction, EGR Delete with FR&RTuning Map out, Custom Black 18" RS4, 35mm H&R springs, S3 brakes, EBC Yellowstuff, front splitter, HID Xenons, S3 tailgate Spoiler, 09 Rear Lights, Retrofit Audi Ipod, S3 Air vents, Bose sound+retrofit JBL Subwoofer 1200W.
    Milltek Cat-back Non-Res for S3 2.0T FOR SALE both 3dr and 5dr PM
    vw754's Avatar
    Nov 2006
    U.K
    1,852
    ive been giving the car some welly last day or so and had no issue's....where is the ' boost regulator sensor' and can i see the 'linkages' mentioned by mr v above?
    Gti Jazz Blue's Avatar
    Feb 2007
    Hampshire
    1,654
    The Turbo has variable vane technology so that the ecu can control the boost generated, the idea is with vanes you can change the exhaust flow. Over time these get gunked up with soot deposits from the engine and the ecu looses the ability to fine tune the amount of boost generated - hence the over boost code.
    You have two options, 1. replace the turbo (same again or a hybrid turbo) 2. remove the existing turbo and clean up the exhaust side. My mate that is a mechanic has done this a number of times with out any problems but it can be labour intensive, so a recon turbo replacement may be a cheaper option depending on your mechanical skills.
    Paul
    Gone not forgotten -
    92 Golf Gti Mark 2 16V.
    VCDS HEX-USB+CAN
    Jul 2010
    interested in your turbo do you still have it?
    Will it fit a 2.00 TDI quatro 2005? as my has just blown up.
    Regards Brooke
    Phatboyruss1's Avatar
    Apr 2010
    Button Moon
    65
    Follow Phatboyruss1 On Twitter Visit Phatboyruss1's Instagram Channel
    Quote Originally Posted by navnayyar View Post
    Where is the boost pressure sensor? Is it easy to remove clean and replace?
    chris.vincent3's Avatar
    Apr 2012
    UK, Portsmouth
    568
    hi does anyone know were the boost preasure sensor is o a3
    vw754's Avatar
    Nov 2006
    U.K
    1,852
    Quote Originally Posted by chris.vincent3 View Post
    if its on the tdi its the black box located on bulkhead with about 6 pipes going to it.
    Aug 2010
    1,540
    Quote Originally Posted by Gti Jazz Blue View Post
    ^^^^ this. can be hard to separate the exhaust side from the rest of it tho. they rust and seize together.
    its not going to be the pressure sensor.
    and the "black box with the six/seven pipes going to it" is all the vacuum pipes that run the egr vvt etc systems. nothing to do with the pressure sensor directly.
    boost pressure sensor will be a 4 wire sensor in the boost pipework somewhere or mounted on top of the intercooler.
    vw754's Avatar
    Nov 2006
    U.K
    1,852
    yes MURRAN is dead right,sorry the boost sensor if im right is on the big pipe just after the maf sensor.
    MxGaza33's Avatar
    Feb 2012
    Glasgow
    138
    I had the same problem with the car going into limp mode on my 2.0 TDI, as crazy as it sounds it was sorted by giving the car a good thrashing! Gave it a couple of runs through the gears revving it just short of the red line and it seems to have cleared out enough of the soot in the turbo to solve the overboost. So if you drive it 'normally' its worth a shot before you start spending lots of $$$!
