AH FabricationsEM Tuning
    david_phillips95's Avatar
    Nov 2008
    538
    URGENT HELP PLEASE!
    Hey guys,
    Got my Sachs Performance Clutch kit fitted today and it is causing problems. There is excess movement in the pedal and the clutch is juddering. I had a new LUK Dual Mass Flywheel installed as the garage said there is not a Sachs DMF available for my S3??? When i check Elsawin it has a section on how to identify whether you have a Sachs DMF or LUK DMF so this leads me to believe the garage was wrong. The sachs clutch kit i have is the same as IGGU and he has had no problems i have PM'd him to try and get his DMF part number but havent got a reply yet. This is urgent as i need an answer for the garage tommorow.
    Can Someone Please Help Me
    Cheers Davie
    mattandrew's Avatar
    Sep 2007
    Up in the hills, Derbyshire
    971
    looking in etka there only seems to be on flywheel listed
    06F105266M remark, LUK Engine code, BHZ BZC
    BHZ mounting time 02/07-06/08
    BZC mounting time 11/06-06/08
    I may be wrong. Mine is in audi at the minute hopefully having a new clutch
    Previous
    S
    Ibis White - 2007
    Current
    A5 Ibis White - 2007
    S3 Black - 2001
    VCDS user
