EM TuningAH Fabrications
    Lapchien66's Avatar
    Apr 2009
    27
    Replace Rear Wiper Blade - How?
    Can anyone describe how to replace the rear wiper blade? Seems pretty tight and if I pull any harder I'm sure I'll bust something...
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    Anyone?
    VCDS USER
    clem2192's Avatar
    Sutton, Surrey
    173
    As far as I am aware its just a pull out jobbie. If you're worried about busting anything why not remove the rear wiper from the car to give you a bit better leaverage?
    Hope this helps!
    Fossie
    Rhubarb Triangle
    3,969
    There are two retaining clips in the centre of the blade. These need releasing with a screwdriver and then the blade just pulls off. When installing the new blade make sure that there is an audible 'click' which indicates the new blade is fastened in place properly. Good luck !
