Monster MotorsportEM Tuning
Results 1 to 13 of 13
    Joe90k's Avatar
    Speed doesn't Kill!
    Apr 2009
    229
    Heated Seat Retrofit - Removing elements from Donor Seats into your existing seats.
    I have missed having heated seats in my A3 this winter from having them in my Golf before.
    As the title says, I have found all the parts to do this, including new seats and climate control for my A3. I am going to dismantle the new front seats and install them into my existing. Has anyone attempted this before? I assume the fabric on the front seats can me removed and the heater elements are only pinned on. I assume this because the elements are a part that is separate to the seat and must be able to be replaced if they fail or short. I did this in my Golf MK4 so it shouldn't be too different.
    I am an auto-electrician by day so I have no problem with wiring etc. I will try to make this into a how to with pictures as I do it.
    So far I have:
    Donor seats (with heating elements)
    Climate Panel with Heated seat switches
    Looms will be constructed using various parts. If anyone is wanting these once I have made the first set I may be able to make others looms for a price depending on the cost of the parts etc.
    Joe
    Click above for my A3 Build thread!
    crypric23's Avatar
    Never satisfied
    Aug 2009
    583
    Why not just put the donor seats in ?
    Or are yours leather and the donor ones fabric?
    Joe90k's Avatar
    Speed doesn't Kill!
    Apr 2009
    229
    Donor seats are all cloth and black mine are half leather with white inserts.
    You have a PM btw.
    Joe
    Joe90k's Avatar
    Speed doesn't Kill!
    Apr 2009
    229
    I'm also doing the retrofit of existing pads as I got the seats cheap and can sell them on after to get some money back. I got the full set black on black cloth with door cards from a 3dr 08 A3.
    Khufu's Avatar
    West coast of Scotland
    5,693
    Do you own ELSA? Its the repair manual & has all the wiring diagrams you will need. This would help show where the wires & possible relay all need to go. It can be downloaded from peer to peer (its huge though) or bought off ebay. All I can say is best of luck replacing the leather & getting it smooth, I've heard its tricky.
    Joe90k's Avatar
    Speed doesn't Kill!
    Apr 2009
    229
    I have got ELSA now so should be quite easy, good idea though. The re-upholstering shouldn't be too much of an issue, my dad is an upholsterer so should be easy enough.
    phil76's Avatar
    Feb 2008
    SHEFFIELD
    559
    We havnt done this before but have fitted new elements to seats which means stripping them down and to be honest that was a right pain in the clock plus the sponges on the seats we did had clips or locaters to hold the elements in place which i am not sure the seats you have will
    Phantom Black S3,Giac stg 1,Evoms intake,Lamin-x
    (to do list,update signature pic)
    Joe90k's Avatar
    Speed doesn't Kill!
    Apr 2009
    229
    Can the clips be removed from the donor seats? Surely they aren't attached permanently to the foams. I don't mind a pain of a job, I'm sure I've had worse. I had to fit the elements to my golf and it was as you say a pain, took me a while but its worth it in the long run. There are only one part number for the foams, obviously there are different for different seat shapes but the elements are identical for all seats. I'll give it a go, the outlay of it is next to nothing and I want heated seats lol
    Khufu's Avatar
    5,693
    Quote Originally Posted by Joe90k View Post
    That is handy, I remember a member getting Audi to replace his base cover under warrenty due to wear & it was all mis-shapen!!
    A write-up would be good :-)
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    I looked into doing this including almost buying donor seats but speaking to people at work who do the seat trimmming i decided to bin the idea as getting the seat covers back on all smooth would be an absolute nightmare as you need to stretch them to get them off in the first place and stretch them again to get them back on.
    Good Luck!
    May 2009
    43
    sideskirts
    Quote Originally Posted by RobinA3 View Post
    Good Luck!
    hi there nice car you have, could you tell me what type of sideskirts you have fitted, and the supplier, would you know if they would fit on my 2007 sline.
    gary
    May 2009
    south yorkshire
    628
    any one know how to code out the heated seat switches in the hvac unit ?
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    Sorry to hijack your thread, bu I've only got two questions:
    Is there difference in construction (I mean the metal parts inside) between the S-Line seats and standard seats?
    Obviously the shape of the foams is different, but is it possible to put the S-Line leather foams onto standard seats?
    VCDS USER
