EM TuningJMB Retrofits
    Jun 2007
    240
    Headlight washer problem
    After the snowy weather I noticed my driver side headlight washer is spraying towards the windscreen and nowhere near the headlight!
    I prized the washer open ( carefully ) and noticed there are two little nozzles to direct the water, or I should say there were two nozzles. I now only have one, wonder if the freezing temps caused the washer fluid to expand and pop it off. There is a circular hole for the nozzle which I assume just clips in but the nozzle is nowhere to be seen.
    Anybody had this problem or know if the part is available separately.
    I'll ask at the dealer when I get my service done, I guess it should be covered by warranty unless they decide I was using the wrong type of washer fluid or some other twoddle!
    ____________
    Sprint Blue S3
    Audi S3 8P
    Aberdeen
    14
    Hi
    I have the exact same problem but on both head light washer units!
    Audi claim that i will need to replace both units as the nozzle type things are not sold seperately!
    I think they said about 70 each...I tried dismantlers but hard to come by!
    I posted a thread on this before but got no replies .....
    Gnic
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,166
    The jet itself is one unit as you can see here:
    8P2 S3
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,166
    Better image of the jet:
    8P2 S3
    Jun 2007
    240
    Would they not replace them under warranty?
    ____________
    Sprint Blue S3
