Results 1 to 23 of 23
    NW London
    So how good is the A3 2.0 Diesel? Potential new owner here
    Hi folks
    Hope you are all doing well.
    Its going to be change my car time soonish. A few models have caught my eye, and probably like most of you on here, it has to be something I like the look of, not what Which Car recommends!
    The 3 door A3 has caught my eye. Am interested only in the 2.0 140hp Diesel model, and really, would like something thats half decent riding than tuned for performance. The SE version looks good, as I like wood and maybe a bit of leather too. Main questions:
    How good are the diesel versions, and does the SE ride better than an S Line?
    How do they handle mileage? Budget is around 10k, so would be looking at an 06 with about 60k on.
    Servicing costs? Have never owned and Audi.
    Thanks for any help
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,110
    Welcome. SE is more comfortable than S-Line, but S-Line will handle better. Servicing costs are resonable if you use a specialist, and they handle mileage well!
    "Will these wheel fit my car PM's will not be replied to, do you research & use the SEARCH button"
    Detailing - Wheel Refurbishment - Shark Performance Software - VagbremTechnic Dealer - OEM Retrofitting - Remus - V-Maxx - Goodridge
    NW London
    Anyone know any of the servicing required for the 2.0 diesel lump?
    Does it need EGR cleaning and PCV valve changing amongst the usual items? These 2 items are sometimes not on the service check list. Well they arent for my ZT Cdti!
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,768
    for 10k I would be looking an s-line
    with that you get more options with the car, better suspension, better looks (bumpers and trim), hold value better etc...
    The 140 engine is good but it can suffer a few problems.
    early models suffered with porus heads but with an 06 onwards car I think you will be fine
    Flywheel issues hounded the early TDI's where the car would judder annoyingly at idle
    Clutch slipage is also common so when testing sit at 40mph and floor it in 6th and see what happens
    Test the glove box to see if the lid slowly lowers itself
    The throttle bodies tend to go on the 140's as well - 175 from Eurocarparts and will take about 15mins to replace, easy fix.
    if you are looking at a TDI around 60k miles, I would look to see if the timing belt and water pump has been changed. other servicing is easy just with regular oil changes.
    Another thing to look at is under the passengers side of the engine. there are 2 air ducts in the sump cover. dont worry if you see a good bit of oily stains on the cover, this is normal but if it looks excessive, it may suggest a fault.
    Oct 2006
    Malvern
    51
    Speaking from experience, I would stay well away from the 2.0 TDI 140 - unless you mean one of the new common rail diesel engines.
    A brief summary of known engine faults are, and are not limited to:
    Dual Mass Flywheel Failure
    Turbo Failure
    MAF sensor failure
    Charge Temperature/Pressure Sensor failure
    Tandem Pump Failure
    Cylinder head cracking
    Injector wiring loom intermittent connections
    Injector faults
    Fuel Filter housing fault
    Intermittent Lumpy Idle
    Miss-firing / total power loss / unable to drive
    Of course have spoken to VW technicians, all can be within specification but it's there combinations that give the faults.
    I wish I'd never bought mine - I've been a VW/Audi fan for more than 10 years, and will now never buy another!!
    Everyday:
    Audi A4 3.0 TDI quattro - 2008, Panther Black
    Upgrades: Planning in progress !!!
    Weekends:
    Audi ur quattro - 1989 (was 2.2 5cyl turbo, currently evolving to 3.6 V8 twin turbo!)
    Registered VAGCOM user.
    NW London
    At what date did the common rail engine enter service?
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,110
    New shape A3 08> more than 10k!
    In pursuit of audiness:)
    Feb 2009
    282
    i got 04 sport with s line spec and enjoy it. a bit of mileage on and so far no problems whatsoever. only wheel bearing needs to be done (but i bet thats due to me changing suspension settings, spacers or something) just keep servicing every7-10k, do cambelt and waterpumps on time and you will be fine. i got some rattling but some of them i fixed myself some i just dont bother also i dont drive like a maniac (well sometimes:D) and like keep my car in good condition. i do aprox 50-60 miles a day motorway so i presume thats easier life for engine and other parts compare to town killing conditions:D once you got it you will be infected with N8's modding addiction very good addiction:D
    Audi A6 2.7 TDI S-Line
    Mods - |Remap | 18" rs6 wheels |
    To be done - 19" wheels | Tints | Sat nav retrofit | RS6 steering wheel
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,110
    Thanks for the reference Luke, and its not an addiction! As I've nearly finished modding!
    Feb 2009
    282
    it is. its like never ending story always find something new that could put in the car
    flying oyster's Avatar
    flying oyster
    Jul 2009
    wimbledon
    545
    ive got a tdi 2.0 on a o4 plate been brill do about 30k a year just keep it service at the right intervals looking forward to mod mine
    S3 8L ming blue westys old car shed loads of mods
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,110
    Quote Originally Posted by madluke View Post
    There plenty I COULD do, but whats in my sig is it now man!
    Feb 2009
    282
    Your to be done list is changing often
    V6Pete's Avatar
    Now running on Bentley's y'all
    Feb 2009
    Northants
    1,492
    Quote Originally Posted by stonesfan View Post
    as I like wood
    That's 2 wood lovers in as many days! What's the world coming to... I guess these are people that would have bought Rovers in another life!?
    A3 3.2 V6 S-Line | Brilliant Black | Full Votex Kit | 18" Cades Bern / 19" Bentley 5 Spokes in flat grey with 215/35 Falkens | Custom Code Remap
    V-Maxx coilovers | Remus exhaust | Pipercross Viper | Goodridge Brake Lines | RNS-E | Bluetooth | FBMFSW
    Previous VAGs: 99 S4 Biturbo | 06 Golf GT TDI | 08 A4 S-Line TDI PD140 | 02 Passat 4.0 W8
    Other toy: Suzuki GSX-R750 K3 Black/Silver
    Leather arm rest for sale | S3 mirror covers for sale | 09 3dr tail lights wanted | Twin grills wanted PM me!
    DJM1982's Avatar
    Essex
    392
    I have a 2.0TDI 140 in my A4 s-line (i know its not a a3). But i have done 8500miles in just under 2 months and it has been as good as gold. Enough torque for motorway driving (which i do), plus i get over 700miles per tank and i do 800miles a week. Could ask for a better compromise between performance and economy imo. But saying that i will be getting it remapped very soon.
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,110
    Nice one DJM.
    flying oyster
    Jul 2009
    wimbledon
    545
    teak is the new piano inlays and dont forget to put the straw hat in the back top mod and i hear saga do a wicked deal on insurance lol
    Aug 2009
    Manchester
    109
    make that 3 wood trim lovers in 2 days!
    NW London
    Quote Originally Posted by V6Pete View Post
    Guilty!!! A 1990 820 SLi
    Plus Soarer TT, Accord Coupe, both of which had loads of timber inside. Glad they do an A3 with wood n leather, and hopefully a little chrome too!!!
    flying oyster
    Jul 2009
    wimbledon
    545
    i just checked the garage and omg the vitesse has got loads of wood in it i never noticed it under the dust better get the pledge out
    kanecullen89's Avatar
    Jul 2009
    237
    Hi,
    I've got a 2006 A3 sport 2.0 TDI. Its coming up to 60k and I havent had any problems except 1 wheel bearing (common fault I think).
    Drives well, enough power for every day use and good with a remap
    Check the thread about cylinder heads cracking. There is a code on the head with the last letter as A, B, or C. The latter are much less prone to cracking heads. Luckly mine in C!
    Jul 2009
    237
    This is the thread:
    http://www.audi-sport.net/vb/showthread.php?76277-[2-0-TDI]-How-to-know-if-your-cylinder-head-will-Crack-(if-it-hasnt-yet)
    NW London
    I guess then, that you are safer going for an 06 plated model on.
