i'm thinking it's probably the gearbox, but it didn't do it when i first had the car, just started recently.
i will have to have the stereo louder
thanx mate
Jokes aside - TBH, whining noises should be investigated as they can lead to bigger problems. You'd need to let a garage take it for a run to check what it could be.
when you go faster does the noise get louder or change! does it only happen at 20 - 30 mph or is it between a certain rev range? if it is the gearbox, the whine would (i think) get louder or a higher pitch the faster you go. it could be a crack in one of the air inlet pipe which is allowing the noise of the turbo to come out!
i will check out your thoughts on whether its revs or speed , and sounds like i need to check inlet pipes as suggested
thanx and sorry for not replying sooner
