Annoying whine
pedro53
NULL
i've got an annoying whine at low speed, usually between 20 to 30mph from my 2.0tdi with dsg.
any ideas
Hi mate, try the A3 8P forum, this one is for the earlier A3's :)
<tuffty/>
I think i've got the same, it's not annoying though...
Might just be the DSG box? I'm no expert though, and i quite like the sound :)
it's still there when the wife's not in the car. but i know what you mean
thanx anyway mate
i'm thinking it's probably the gearbox, but it didn't do it when i first had the car, just started recently.
i will have to have the stereo louder
thanx mate
Jokes aside - TBH, whining noises should be investigated as they can lead to bigger problems. You'd need to let a garage take it for a run to check what it could be.
when you go faster does the noise get louder or change! does it only happen at 20 - 30 mph or is it between a certain rev range? if it is the gearbox, the whine would (i think) get louder or a higher pitch the faster you go. it could be a crack in one of the air inlet pipe which is allowing the noise of the turbo to come out!
i will check out your thoughts on whether its revs or speed , and sounds like i need to check inlet pipes as suggested
thanx and sorry for not replying sooner
