Sky InsuranceChris Nott
    bearder2006's Avatar
    Jun 2009
    205
    Audi A3 rear wiper motor help
    hi ive a a3 55 reg and my rear wiper motor is no good the number is 8E9 955 711C there is one on ebay but the end letter is E NOT C will it still fit ? all the numbers are the same before the C
    Same problem with my motor. Its leaking when you use rear wash. Filled the boot latch with water then cause the boot sensor to fail setting off the alarm.
    Just ordered a new motor from Audi cost is 90. The leak is due to internal corrosion on the shaft and the car is a 55 plate too. A motor from a breaker will probably have as much wear so may not be a good buy.
    Oct 2009
    Plymouth, Devon
    71
    Hi just seeN your post if you like I can get our parts guy to check etka tomorrow and will post an answer around 2ish is that ok?
    Oct 2009
    Plymouth, Devon
    71
    Sorry just seen this
    http://cgi.ebay.co.uk/2006-AUDI-A3-R...#ht_1792wt_722
    35 plus postage hope it's helps
    Oct 2009
    Plymouth, Devon
    71
    Sorry for the late reply I've been out sick just checked on etka for you the part number 8E9 955 711 C changes to D then to E which is current so yes that motor will fit fine
