Volks AutosMonster Motorsport
    Jul 2007
    Sheffield
    13
    Question Vibration at speed after a bump in the ice
    Hi all, Just wondering if anyone has any suggestions about a problem I've been having.
    I banged my front driver's side wheel into a kerb after sliding on some ice last week. I've had the wheel rebalanced and the tracking done, but there is still an annoying vibration when driving at motorway speeds, which gets noticably worse when steering to the left, but almost disappears when steering to the right.
    It seems like it ought to be a wheel balance problem, but I've tried a spare pair of wheels on the front with no change.
    Took it to my local garage who gave it a quick visual inspection and couldn't see anything obviously damaged, so am just wondering where to go next!
    thanks
    (2004 A3 2.0TDi 140)
    david_phillips95's Avatar
    Nov 2008
    538
    I had the same problem except passenger side, turned out i had damaged my wheel bearing. Try jacking the car up to see if there is any play in the wheel, you should be able to hear the bearing its a whirring noise you tend to get.
    Davie
    Jul 2007
    Sheffield
    13
    Ahh, hadn't thought of it being the bearing - thanks, I'll have a look
    Nov 2008
    538
    Not a problem, you will also notice it gets worse as you accelerate due to the RPM of the wheel increasing.
    Davie
