EM TuningMonster Motorsport
Results 1 to 15 of 15
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,851
    What's the problem here when I cut engine off?
    My car used to cut off smoothly when i parked it up but latley its doing this...any ideas?
    If i press the clutch pedal in and keep it there and switch engine off it cuts out smoothly.
    ITS MY FIRST VIDEO POST,THINK IVE GONE WRONG SOMEWHERE.MY....APPOLOGIES.
    CLICK ON THE ACTUAL PICTURE TO PLAY THE VIDEO
    2.0 tdi 140 http://s851.photobucket.com/albums/a...MOV00439-1.flv
    Full leather/19"wheels/cruise/
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,386
    seem that everyones a3/s3 is doing it. when you press down clutch and turn it off it goes off smoothly. and if you don't it sound like it's falling apart.
    s3 Ibis White ... Build Thread
    / Black Grill / FbMfSw / Sunroof / Hill Hold / Armrest / Black Leather-Alcantara interior / Rear Parking Sensors / Heated Seats / Folding Mirrors / Cruise / Rns-e mk2 // ttrs-Brembo Brakes / 12mm spacers / Forge Short + Side Shift / 42dd's / ITG CAI / GfB DV+ / Forge Catch Can / Milltek TBE / Forge Twin IC/ Autotech HpFp / H&R ARB's / WALK / KW v3's / RS4 fpr / Loba&Sachs clutch / Revo Stage 2+ / ...
    vw754's Avatar
    Nov 2006
    U.K
    1,851
    Nice to know im not alone then
    david_phillips95's Avatar
    Nov 2008
    538
    I always thought it was just the gears in the gearbox rattling as they come to a stop, this would explain why the noise goes away when you dip the clutch. Just an idea mind you.
    Davie
    Phantom black S3/
    Mar 2009
    137
    This happens when you flywheel is in a bad shape or damadged. This use to be my problem, changed the flywheel and all OK!!!!!
    Phantom Black S3/ APR stg 2+ / Forge CAI / APR HPFP / Miltek TBE / Forge DV / Forge Catch Tank / Forge T. body / VF Engine mounts / ECS EM / KW V3 / 19" BBS CH "Black" / 18" Team Dynamics Motorsort / Denso Iridium IK24 / Forge Twincooler / Helix Race Clutch + Flywheel / H&R ARBs / JVC Multimedia + TV Tuner / Kicker sound system over 3,000W RMS / TT-RS Steering wheel / Whiteline Anti-lift kit / Brembo Porsche GT2 BBK / soon: RECARO POLE POSITION SEATS,
    26,716
    flywheel
    vw754's Avatar
    Nov 2006
    U.K
    1,851
    thanks for all the replys,will it last a while or is this a warning,car drives ,idles, ok ive no other problems
    Phantom black S3/
    Mar 2009
    137
    The sooner you change it the better, so that your clutch doesnt hold any extra pressure/damage... and also you car should go a little better than..
    Nov 2008
    538
    Quote Originally Posted by mrgicm View Post
    My car is booked in on the 25th January for the clutch to get replaced with my sachs perfromance one. I will find out what state my DMF is in then as it will be exposed, I would be surprised if my DMF was faulty as i have had this noise since i bought the car with less than 5000 miles. Maybe some flywheels are noiser than others but i wouldnt say that this noise means your flywheel needs replaced. If your flywheel was on the way out you would get vibration through the clutch pedal.
    Davie
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,386
    Quote Originally Posted by david_phillips95 View Post
    Davie
    mine does it since day one.
    vw754's Avatar
    Nov 2006
    U.K
    1,851
    mines been doing it a few months,il leave it be,il replace complete clutch kit flywheel and release bearing if it ever goes.
    Nov 2008
    538
    Quote Originally Posted by S. View Post
    The flywheels must wear out within the delivery mileage, that would explain it
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,386
    will be replacing it when it won't hold power anymore.
    Nov 2008
    538
    Sounds like a good idea to me
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,386
    well for now it's ok. but will go for twintercooler and maybe fuel pump so i think it will be necessary
