    darren_wheeler's Avatar
    55
    S3 S-Back wheel offset help
    Hopefully someone can help out as i know a few of you run these wheels.
    BBS CH 19's
    the size that most seem to go with is the 8x19 ET 50.
    i want to know if it is possible to run the 8.5x19 with a 35 offset.
    i really prefer the 35 offset as it has a deeper dish look to it.
    20mm lower as well.
    any help most greatful.
    thanks
    darren wheeler
    Aug 2007
    363
    Deffo will not fit.
    A4 setup wheels will stick out
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,110
    I will fit, but you will have to run 215/35s and you won't be able to slam it either. Only if you run negative camber you will avoid rubbing and you can slam it. Here is Lomax's Mk5 GTi running ET35 all round on 19"x8.5s:
    "Will these wheel fit my car PM's will not be replied to, do you research & use the SEARCH button"
    Detailing - Wheel Refurbishment - Shark Performance Software - VagbremTechnic Dealer - OEM Retrofitting - Remus - V-Maxx - Goodridge
    55
    [QUOTE=N8;886107]I will fit, but you will have to run 215/35s and you won't be able to slam it either. Only if you run negative camber you will avoid rubbing and you can slam it. Here is Lomax's Mk5 GTi running ET35 all round on 19"x8.5s:
    Many thanks. sorry for the next question. what are the pros and cons on running that level of Neg camber. thanks
