S3 S-Back wheel offset help
darren_wheeler
Hopefully someone can help out as i know a few of you run these wheels.
BBS CH 19's
the size that most seem to go with is the 8x19 ET 50.
i want to know if it is possible to run the 8.5x19 with a 35 offset.
i really prefer the 35 offset as it has a deeper dish look to it.
20mm lower as well.
any help most greatful.
thanks
darren wheeler
Deffo will not fit.
A4 setup wheels will stick out
I will fit, but you will have to run 215/35s and you won't be able to slam it either. Only if you run negative camber you will avoid rubbing and you can slam it. Here is Lomax's Mk5 GTi running ET35 all round on 19"x8.5s:
Many thanks. sorry for the next question. what are the pros and cons on running that level of Neg camber. thanks
