EM TuningVolks Autos
    Dec 2009
    155
    Anyone with xenons changed sidelight bulbs?
    fitting xenons an wonderin if i should put diff sidelight bulbs in?
    iv seen led ones also just blueish ones or super bright white.
    can anyone giv me an idea of a good set to go for??
    10blazin's Avatar
    HYPERDRIVE NEEDED
    Dec 2008
    gorton
    3,272
    there,s a thread on this somewhere , do a search if not someone will put a link soon enough
    Mick a3's Avatar
    Mellow Yellow
    Apr 2009
    Greenock,Scotland
    269
    I bought these, Had them in over a month with not a problem and they match my xenons perfect and theve lasted this harsh winter so far.
    http://cgi.ebay.co.uk/AUDI-A3-A4-A6-...item41474404c3
    Dec 2009
    155
    cheers
    they say not suitable for after 2005 tho
    i hav 2006 :/
    Jan 2006
    UK, Blackpool
    100
    A bit of a silly question maybe but how do you change A4 sidelight bulbs? Ive taken my headlamp unit out but cant see how to get to either the high beam bulb or the sidelight bulb!! Do yoiu have to take the dark plastic shroud off the unit somehow as it seems to be fixed on with 6 clips?
    Any info would be great
    Sarah's A3's Avatar
    MODERATOR V6 S3 Hybrid
    Cheshire to Perth AU
    5,923
    when i changed mine, i loosened the headlamps to gain a bit more room then had to move the retainer/clip to one side on the back and the black cover on the back just pulled off. Was then able to access all bulbs to change. Ended up changing all to get rid of the amber ligh bulbs to super white. Also changed the idicator bulbs to the 'soap bubble' diadem bulbs, looks ace now.
