Chris NottAH Fabrications
Results 1 to 19 of 19
    heyadamhey's Avatar
    May 2009
    Joburg, South Africa
    126
    TDI Hybrid Turbo considerations
    Hi guys
    I seriously considering getting the hybrid treatment done on my turbo.
    How necessary is it to upgrade the following:
    Fuel system? (pump, injectors, anything else?)
    Clutch? (apparently a good idea to get an uprated clutch)
    Intercooler?
    Exhaust?
    Obviously a remap
    What other considerations are there?
    Adam
    Akoya TDI 140, 18" S4 Rims, VCDS, H&R
    Getting Hybrid treatment
    heyadamhey's Avatar
    May 2009
    126
    so after doing some more phoning around, it seems the possibility of having my turbo 'hybridised' is not an option here in SA
    but... I did find out that the Taureg V10 uses two VNT1852 turbos. surely one of these would be very close to the GT1749 with a 52mm exhaust wheel?
    Does anyone know if this'd work? presumably a new manifold would be in order, but is it worth considering as an alternative to having mine milled out?
    devonmikeyboy's Avatar
    As far from JBS as possible !
    Feb 2007
    1,257
    Quote Originally Posted by heyadamhey View Post
    http://audi-sport.net/classifieds/sh...n-pipe-&cat=15
    06 Audi 2.0 PD140 Sport TDI Quattro S-LINE.
    Old engine 330 bhp @ flywheel 263 bhp @ wheel 490 lb torque. Audidriver write up HERE
    Now stripped and playing with an uprated Cryo treated engine fitted with bigger turbo,water/methanol,uprated injectors etc etc.Wanting 400 bhp and 500 lb torque.
    Other car 500+ bhp MK4 Golf R32 turbo.
    In pursuit of audiness:)
    Feb 2009
    282
    thats for me)))
    Audi A6 2.7 TDI S-Line
    Mods - |Remap | 18" rs6 wheels |
    To be done - 19" wheels | Tints | Sat nav retrofit | RS6 steering wheel
    Feb 2007
    1,257
    Now provisionally sold to Madluke who`s girlfriend is
    Last edited by devonmikeyboy; 12th January 2010 at 18:01. Reason: Got excited and needed some tissues.
    heyadamhey's Avatar
    May 2009
    126
    If postage to South Africa wan't an issue and it being sold wasn't an issue, you'd have had a buyer, Mikey.
    any thoughts on the GT1852V ? I noticed another user on here has one fitted to a 2.0TDI
    Feb 2007
    1,257
    Good turbo but what power do you want to be make ?
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,133
    Quote Originally Posted by devonmikeyboy View Post
    The pic Luke showed me, I was abit
    heyadamhey's Avatar
    May 2009
    126
    similar to the 52mm you suggested, I guess. 220ish bhp.
    I just can't find anywhere in South Africa that will modify my current turbo...
    If I did go with that, would my clutch handle?
    Feb 2009
    282
    Quote Originally Posted by N8 View Post
    N8 lie lie and lie some more:D you jealous K(C)ow:D
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,133
    Quote Originally Posted by madluke View Post
    Sep 2007
    Ellesmere Port
    160
    With the hybrid you lose below power 2500rpm, but there is awesome amount of power from 2500rpm right to red line...
    So when driving you have to drive differently and change down to get the turbo in because 5th an 6th the revs will be out of the turbo range... this is after a remap as well...
    Am waiting now for mine to settle to see how the MPG is affected...
    Audi A3 2.0 TDI Sport, Hybrid Turbo, Sat Nav RNS-E, Bluetooth, Bose, Parking Sensors, Custom Bluefin Map, Black Diamond Drilled and Groved Front Discs, Black Diamond Preditor Pads (All Round), Roof Spoiler, Cruise Control.
    Sep 2007
    Ellesmere Port
    160
    PS - Nope... mine slips in 4th 5th an 6th with foot down hard... but driven carefully and not hammered all the time you'll be ok for a while...
    heyadamhey's Avatar
    May 2009
    126
    Ok, so I finally found a place that will modify my turbo and remove the cat, but they don't do remaps.
    Would it be driveable before getting it remapped? i.e. would it just constantly go into 'limp mode'?
    Would the decat throw any ECU errors? I've heard people mention the lamda sensor (?)
    Adam
    sammi's Avatar
    verwood, Dorset
    346
    Follow sammi On Twitter
    I am no expert but would have thought it would need mapping to run safely as I am sure the boost levels will be increased over standard. If you are careful and stay off the power then you should be ok for a short period of time
    Feb 2007
    1,257
    The turbo can be run without a remap but will be very laggy and will not make much more power then your stock turbo plus if you try to drive it hard it will go into limp mode. Removing the CAT will cause no problems at all as with it being a diesel it has no censors in the CAT. Untill you sort out where you are going to get a map from no point really fitting the hybrid turbo. If you buy yourself something like an Alientech box http://www.alientech-to.it/index.php...id=6&Itemid=13 like i have you can get maps emailed to you and upload them yourself.
    heyadamhey's Avatar
    May 2009
    126
    Thanks guys - was really just checking if I'd be able to drive if from the turbo shop to the garage to get it remapped...
    Thanks for the link, Mikey, any idea on what they go for?
    Feb 2007
    1,257
    In England you can buy it for 295 with a sports, economy and standard map already on the device.http://www.tuningtools.co.uk/aliente...formation.html. Several "remap companies" already sale the device rebranded as their own device with their "own" maps on like Chipped UK ( now changing their name to Viezu ) who call it a ST3 http://www.chippeduk.com/content/en/...ng_System.html , Derv Doctor,RS Tuning etc . I bought the device direct with no maps on for 150 from Alientech.
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,133
    Shark Performance also do custom maps via post with their STS unit.
    www.sharkperformance.co.uk
