Results 1 to 13 of 13
    jsws3's Avatar
    Oct 2009
    443
    Bluetooth phone prep
    Iv just tried to pair my phone with the car but it asks for a pass code and i dont know it .
    Is there a way of finding it out so i can pair them .
    Any help would be g8
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    it will be 0000 9 times outta ten thats the default
    jsws3's Avatar
    Oct 2009
    443
    Thanks bud ill try it in the morning
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    no problem its the most common code like i said, let us know how you get on
    jsws3's Avatar
    Oct 2009
    443
    Ok mate will do
    scottie123's Avatar
    Oct 2008
    1,888
    on my blue tooth, it is 1234.
    You can check what the code is with vcds if you have also.
    05 SB SE BKD
    Build Thread
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    thats the other one couldnt remember it last night had sever mmental block (as always :P) cheers scottie
    jsws3's Avatar
    Oct 2009
    443
    I tried 1234 but it was unable to pair with the phone .
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    did you get the same result with "0000"
    jsws3's Avatar
    Oct 2009
    443
    The wife at home untill 7 o clock so ill have to wait till then mate
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    alright well see then, then :P
    jsws3's Avatar
    Oct 2009
    443
    Thats the one thank you .will it automaticly connect to my phone when i get in now ?
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    no problem glad you ggot it running and as long as your phones bluetooth is on the pairing autorises the device, kinda like if you gave someone a key to your house
