EM TuningAH Fabrications
Results 1 to 34 of 34
    Dec 2009
    Birmingham
    88
    A3 xenon headlight upgrade
    Hi everyone
    I'm sure this has been asked before, but can anybody help me and tell me whether it is possible to retrofit genuine audi Xenon headlights to my 2007 car?
    2007 A3 S-line 170 TDI S-tronic
    Brilliant Red, Bose, RNS-e with bluetooth and SDS multi-function, factory fin, Ipod, Full Vienna Leather, interior ambient light pack, non smoking pack, 18" BBS split rim's, cruise control, 09 vents-climate control-switches, Cupra splitter
    Essex
    116
    I've been wondering this as well, so thanks for posting. I'm sure someone on here will know ...
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    yeah but you need the units with autolevelling in them to check out kufatec they do the adaptation looms im just waiting for a set to come at teh right price before i do mine
    Dec 2009
    Birmingham
    88
    Do all the audi xenon units not have autolevelling in them? How does the autolevelling work?
    Jun 2009
    173
    All factory fitted xenon headlights have headlight washers and auto levellers. The auto levellers work to try and avoid blinding people because the lights are very powerful. For example if you're going up a hill they would level down.
    MK5 Golfs have the auto leveller attached to the rear suspension, A3 maybe similar?
    27,094
    Yes it is possible but do research on the site as I've discussed it to death about whats involved.
    All cars have 2 sensors, 1 on each axle including the Mk5 as its same car almost as the 8P
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    i thought that the bi xenon units had it built in?
    27,094
    No disrespect mate but think you're confusing the levelling motors with the axle height sensors, completely different things, levelling motors yes are part of the headlights & in some cases are actually built into the headlights themselves, some have motors that can be detached from the headlights & replaced like the old 8L did & iirc the single vision xenons do on the 8P.
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    yeah youre right i am gettting confused, sorry first thing in the morning, so you really require looms for the height sensors the sensors themselves and an adaptation loom for the lights and lights with the levelling motors built in. I must admit even without the autoleveling having your xenon through a well set projection lens will be far less dazzling than some of these hids that are blinding everyone on the street these days. not heard from you in a while nhn how come you never drop by vagoc anymore (im Phil on there)
    27,094
    You need a loom for the sensors on the axles to the levelling control module which is located just to the right of the radio bolted on to the console chassis, kinda hidden, you need either an adapter loom for the halogen to bixenon or whatever xenons you are installing or amend current wiring to suit, now if its single vision xenons then can plug in directly as its same wiring mostly & 10 pin then code, but also reliant on a highline module being installed to code as xenons fitted, then you need to add wiring from the headlights to the levelling controller, nice little job for sure, gotta do for someone soon.
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    if i ever get a set of xenons for the right price on ebay ill do them just leaving it to chance that way
    smudge_don's Avatar
    Dec 2008
    Sutton, Surrey
    2,941
    "Search" button is your friend
    Currently driving a 55 plate Ford Mondeo ST. But as Arnie once said...
    I'll be back!!!
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    let me know when youve done the conversion nhn im highly interesed and considering throwing money at it
    27,094
    Already done mate before & converted my xenons to bixenon adaptives, so if you want it done then say so & can look at getting parts.
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    well the only bit that im unsure about is the level sensors ill hit you up once ive got cash, got a prior verbal agreement to buy a two tone interior for my car which comes first i figure i can get the headlighs balasts and bulbs off ebay for 400 im geussing i'd still need a controller level sensors and conversion looms right? also an approximate price would help, gives me something to aim for :P
    27,094
    Check your module 09 with vagcom for part number 1st.
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    ill check tomorrow afternoon mate, got some of the final wiring to do for my zune player integration on my double din unit also gotta wire in some risitors into my led interior lights to ensure they stay off when the doors are shut, not just go into a dim mode
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    what a job some things are never easy some updates will be in my build thread once i get the stuff off the camera
    part number : 8P0907279A
    27,094
    Well your module is a basic version, not highline so have to upgrade that 1st, not easy/nice job.
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    woopie all the fun, but ill keep sourcing parts as they come thanks man, what part numbers would be acceptable?
    27,094
    Depends if you want single xenons or bixenons, C would do single & F & K will do bixenon.
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    whats the difference, is it just the corner following?
    c_w
    1,061
    I may have an OEM set of bi-xenon (06-08) headlights for my 56-plate 2.0TDI Sport with Halogen lights. From what I've read it seems with an adaptor loom they will work once coded? I assume that the main beam wiring, instead of lighting up a bulb, operates the solenoid for the bi-xenon high beam flap?
    The other concern now is what NHN wrote about having the right MODULE 09 fitted to be able to code for xenons properly, or is this for something else like the levelling? As I assume they definitely won't work without being set on the proper code.
    Khufu's Avatar
    West coast of Scotland
    5,693
    You will indeed need the right module. Without it you can tell the car you have them so they wont work, it will just give you a coding error.
    c_w
    1,061
    Thanks for that. Is there any rough guide to knowing if it will have the right module or not?
    On many threads it's been said that it just requires a coding change so plenty of cars must have the right module otherwise it would always be a must if you want to retro fit xenons?
    Dec 2008
    252
    I have 8P0 907 279 K which is one of the ones that works correctly. Ones that superseed that one most likely will also work.
  28. #27
    c_w
    1,061
    Quote Originally Posted by fizz View Post
    What reg & spec originally is your car? Mine's a 2006 56 2.0TDI Sport.
  29. #28
    c_w
    1,061
    For info my 56-reg 20TDI SPORT has a 8P0907279 F module.
    I beileve this will be fine to code for bi-xenons as per NHN's post?
    Does anyone know on VCDS would I select "Bixenon WITHOUT additional main beam", or "Bixenon with DRL"?
  30. #29
    27,094
    Uh no it doesnt quite work that way all the time, it would be the module that supersedes this within etka, you cant assume say a J, L, M etc module will do the same job as this isnt so, for the record the K has now been superseded by the P version.
    Quote Originally Posted by c_w View Post
    F module is 23 byte so will be fine, fact you can see these oiptions means will work, you need to select bixenon with drl of course these settings are only relevant when wiring is also correct.
  31. #30
    c_w
    1,061
    Thanks for the info. I didn't go any further into the module other than confirm it's an "F" (I got those descriptions off a screen grab I've seen in a DRL thread). So I assume it's ok for bixenon.
    With regards to the wiring it's a case of getting a 10-14pin adaptor? What are the extra 4 pins for? directional lights or something? And assuming it's a "correct" 10-14pin adaptor loom the bixenon work ok (ie full beam works ok)?
    Also, what happens if you plug them in and try the lighs WITHOUT recoding? Could something get damaged or will they just not work properly?
    Sorry for so many questions!!! Appreciate any help.
  32. #31
    27,094
    Not all the pins are used, on my bixenon adpatives it uses 11 pins, so without rechecking, bixenon standard possibly uses 13 which given the adaptives have canbus modules built into them so less wiring, thus bixenon standards are not canbus connected directed in the headlight, work over the wires so chances are more wiring.
    Anyway just wire them up properly, dont run before you can walk cause if you do damage something then that is a very costly impatient test huh, lol, but you should only get DIS errors/warnings & canbus errors, but upto you.
  33. #32
    Dec 2008
    252
    Thats what I meant
  34. #33
    c_w
    1,061
    Ah IC that makes sense. I guess in a few years there will just be one single wire that controls the whole light unit
    Do you happen to know the pin-outs/wiring for a 10pin to 14pin plug convertor loom so I could check? I have read that some of these aren't done properly for some reason, so could check with a meter the orientation of the wiring before plugging.
    On the kufatec website for this 10/14 convertor loom it has 2 spare wires http://www.kufatec.de/shop/product_i...-8P-Sport.html and says;
    "The added single wires need to be connected to the on board supply system control unit in order to release the Bi - Xenon switch. " what does this mean? Is that a connection on the actual headlight that is connected seperately to the main plug?
  35. #34
    c_w
    1,061
    In answer to my own question the extra wires plug in to the Module 9 under the dash and are effectively 12v supplies to the solenoid flaps in the bi-xenon headlights to activate main beam. You can test them by simply connecting them directly to the +ve feed off the battery.
    However (and I'm sure I've read it in a thread on here somewhere), the sidelights do not light up using the Kufatec loom (everything else works ok, main/dipped/indicators etc). Is this just purely a coding issue or is this an inherent problem with the Kufatec loom??
