EM TuningMonster Motorsport
Thread: Vag-Com Error
    aristides's Avatar
    Aug 2008
    Greece
    543
    Vag-Com Error
    Hola folks.
    Popped my VCDS prog today to do some work , and noticed this Engine Error.
    I know its intermittent, but i never felt anything going wrong with the car
    Should i go check it?
    Address 01: Engine (CAX) Labels: Redir Fail!
    Part No SW: 03C 906 022 HW: 03C 906 022
    Component: MED17.5.20 G 2339
    Revision: D5H03--- Serial number: AUX7Z0H4FNU0CO
    Coding: 0000072
    Shop #: WSC 04030 207 92648
    1 Fault Found:
    000308 - Oxygen (Lambda) Sensor B1 S1: No Activity
    P0134 - 000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00110000
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 34451 km
    Time Indication: 0
    Date: 2010.01.01
    Time: 17:03:56
    Freeze Frame:
    RPM: 1743 /min
    Load: 34.1 %
    Speed: 36.0 km/h
    Temperature: 44.0C
    Temperature: 20.0C
    Absolute Pres.: 990.0 mbar
    Voltage: 14.224 V
    Readiness: 0000 0000
    FOR SALE:
    RNS-e 2013 DVD, BK Version, NOT unit, DVD disc
    Steering ECU : 1k0 953 549 AH, ideal for Cruise Control retrofit
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    I wouldnt worry, clear the fault code and see if it comes back. If the Oxygen (Lambda) Sensor fails you will get an engine warning light but it will still drive ok so you will not be stuck. this cold weather plays havoc with the electrics. My Vagcom says i have a failed glo plug pre heater indicator.....and i dont have a diesel....
    Address 01: Engine Labels: 022-906-032-BDB.lbl
    Part No SW: 022 906 032 CB HW: Bas isX 3
    Component: MOTRONIC ME7.1.1G 5604
    Revision: 00000000 Serial number: AUX7Z0D2FN40HY
    Coding: 0000178
    Shop #: WSC 00000 000 08192
    1 Fault Found:
    18025 - Glow Plug Pre-Heat Indicator (K29): Open or Short to Ground
    P1617 - 001 - Upper Limit Exceeded - Intermittent
    Readiness: 0110 1101
