Chris NottMonster Motorsport
    martyboy's Avatar
    Feb 2009
    Scotland
    528
    Add martyboy on Facebook
    Engine management light on!!!
    hi, my engine light has came on today, so gave it a scan with vag-com and this is what has come up.
    can anyone tell me where the "intake manifold flap" is an how much this is likely to cost to repair?
    thanks
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 016 FF HW: 028 101 190 5
    Component: R4 2,0L EDC 0000SG 6337
    Revision: 12345678 Serial number: AUX7Z0DDFN90RI
    Coding: 0000072
    Shop #: WSC 66565 257 00032
    3 Faults Found:
    19557 - Motor for Intake Manifold Flap (V157): Open or Short to Ground
    P3101 - 000 - -
    Freeze Frame:
    RPM: 819 /min
    Torque: 28.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.36 V
    Bin. Bits: 11000111
    Torque: 132.0 Nm
    Torque: 0.0 Nm
    17075 - Fan 1 Control Circuit: Short to GND
    P0691 - 000 - -
    Freeze Frame:
    RPM: 798 /min
    Torque: 28.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.36 V
    Bin. Bits: 11000111
    Temperature: 75.6°C
    Duty Cycle: 9.6 %
    19558 - Motor for Intake Manifold Flap (V157): No Signal
    P3102 - 000 - -
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.31 V
    Bin. Bits: 00000100
    Torque: 0.0 Nm
    Torque: 354.0 Nm
    Just taken delivery of my Glacier White S-Line Sportback
    martyboy's Avatar
    Feb 2009
    Scotland
    528
    c'mon guys, surely someone can help me out here, please???
    Oct 2006
    Malvern
    51
    Hi Marty,
    I think it will be one of the fuses has blown.
    I think the fuse for the IMF and the Fan is the same, and is found on top of the battery.
    What caused it to blow is another thing!
    Everyday:
    Audi A4 3.0 TDI quattro - 2008, Panther Black
    Upgrades: Planning in progress !!!
    Weekends:
    Audi ur quattro - 1989 (was 2.2 5cyl turbo, currently evolving to 3.6 V8 twin turbo!)
    Registered VAGCOM user.
    martyboy's Avatar
    Feb 2009
    Scotland
    528
    aye mate, fuse has blown.
    fault cleared, fuse replaced, switched on engine, light came back on after 5 mins!!!
    do you think it might have anything to do with this cold spell?
    flap frozen solid, or something similar???
    Oct 2006
    Malvern
    51
    Marty,
    It could be a frozen flap. But I'd be surprised, I'm sure VW spent millions cold weather testing - but then judging by all their other faults with this engine I wouldn't be too sure.
    I think the flap is a reasonably common faulty component.
    It might be worth determining whether its the flap our the fan causing the fuse to blow. Try unplugging the flap, replacing the fuse and see if the fuse blows again. The flap is only used to stop the engine when you key off or if the engine runs away with itself, so the engine should run OK with it disconnected (but you will still get the fault code).
    I think you may have to replace the flap unit (I think I read somewhere that GSF or EuroCarParts can source these?).
    Good Luck
    Everyday:
    Weekends:
