JMB RetrofitsAH Fabrications
Results 1 to 11 of 11
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    Advice Needed: Seats Removal - Front and Rear
    Hi,
    Could anyone please give me some advice on how to remove the front and rear seats?
    Do I need any special tools?
    Wanna stick some S-Line seats in and wanted to know how to deal with it quickly and efficiently.
    Is it difficult?
    VCDS USER
    27,122
    Fronts need spline sockets to undo 4 bolts in base rails then lift out taking note to unplug any cables undernetah plugge dinto floor sockets, rears are different, base is held in place by metal bracket part of the seat frame & pushed into plastic locators at front & then the hooks can be released for base rear fixings to slide forward or back & out iirc, some force to lift up to remove base front fixings & rear upper is locked into some groove like locators on left/right & depending if split seat iirc the middles are held in place by a bolt & metal piece that holds them into a channel, should be obvious once started tbh mate, I may ahve missed something small out but overall its this.
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    Thanks for your help Nigel & Scott!
    So I take it I need that: http://www.diytools.co.uk/diy/Main/P...roductID=93459 , right?
    What do I fit those Spline Sockets into? Shall I go Halfords to buy it?
    Sorry, but I'm a bit of a beginner.
    VCDS USER
    27,122
    huh, scott, where's he on here.
    Anyway no thats wrong set, get yer self one of these sets, great for use now & future
    http://www.halfords.com/webapp/wcs/s...egoryId_165469
    Make sure you have a 1/2 socket set or adapter for your socket set to fit to undo & do up.
    Mar 2009
    Staffordshire
    1,249
    27,122
    lmfao
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    Got all the tools today, now it seems like an easy task! Thanks again for the advice!
    VCDS USER
    audi58's Avatar
    Milton Keynes
    149
    lmfao
    Do you know the size of the spline bit socket to get the front seats out?
    A7 3.0 TDI 245 S Tronic --Google Maps Navigation Upgrade - Adaptive Lights - Lighting Pack - High Beam Assist - Tinted Windows - DAB Radio
    Previously Owned:
    A5 3.0 TDI 240 S Line -- 3G Navigation
    A4 2.0 TDI 143 S Line -- MMI Navigation - Tinted Windows - DAB Radio - Heated Seats -
    A3 Sportback 2.0 TDI 140 SE -- Remap (thanks to Shark Performance) -- Tinted Windows -- Chrome Roof Rails -- Full Leather Interior -- DIS Retrofit -- RNS-E --
    27,122
    10mm spline as just tested mine.
    audi58's Avatar
    Milton Keynes
    149
    Perfect! Thanks so much
    Previously Owned:
    Mr. B's Avatar
    English...not so good
    Jan 2012
    Bristol
    944
