Results 1 to 7 of 7
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    Help! Passenger's window won't close! VCDS Code.
    Hi guys,
    Something happened and I can't close the passenger's window.
    Got this error code through VCDS:
    00933 - Electric Window Motor; Passenger Side (V148)
    012 - Electrical Fault in Circuit
    Did the testing - When trying to Lower/Raise the window I only hear a tick in the door but no movement of the window. VCDS says "inactive" with both test.
    Thought it might be a fuse but it wouldn't make any sound then, am I correct?
    Which fuse is responsible for the window motor on passenger's side
    It might get unpleasant when it starts raining!
    There's a 3inch gap and (touch wood) I hope no one will try to find their way inside.
    I will try to take the door card off tomorrow, unless someone's got a solution.
    Any help appreciated!
    VCDS USER
    Aug 2009
    Darvel, scotland
    135
    i think the motor is at fault m8 or could be regulator is faulty causen the motor to jam up
    GIAC pump & race map WITH CONTROLER, VF ITAKE ,AUTOTECH HPFP,MV DOWNPIPE & MILTEK CAT BK,RS4 REG,UPRATED OEM DV, CUSTOM ENGINE COVER, BOOST GAUGE & POD, H&R SPRINGS, OEM BLACK WHEELS, FORGE CATCH TANK AND WASHER BOTTLE ,RNS-E SAT NAV BLUETOOTH,FLAT BOTTOM, BUCKETS,PRE-FACE TAILLIGHTS TINTS
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    I'll try to look at it tomorrow, remove the door card and see what is the cause. Hopefully it won't be anything serious.
    VCDS USER
    kaz219's Avatar
    Jun 2008
    Manchester/Liverpool Uni
    1,796
    try holding the lock button and see if that shuts it ?
    if it does, then its a switch fault.
    Audi A3 S-Line DSG - sold
    Golf Mk4 Autograph - sold
    Currently Vtec'in around in an Accord Type R :P
    For Sale: ST3 Remap Console - PM Me :P
    Vagcom'd too
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    I've tried both switches and neither of them shut the window. As for the lock button, holding it does not close either sides.
    VCDS USER
    kaz219's Avatar
    Jun 2008
    1,796
    Vagcom'd too
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    Don't think those are relevant to my problem mate.
    Appreciate the effort though.
    Update:
    Took the door card off, removed the window motor, shut the window. The motor would not spin even if taken out so I believe that's where the fault lies.
    Has anyone got a spare one?
    How much am I gonna have to fork out?
    VCDS USER
