Hi guys,
Something happened and I can't close the passenger's window.
Got this error code through VCDS:
00933 - Electric Window Motor; Passenger Side (V148)
012 - Electrical Fault in Circuit
Did the testing - When trying to Lower/Raise the window I only hear a tick in the door but no movement of the window. VCDS says "inactive" with both test.
Thought it might be a fuse but it wouldn't make any sound then, am I correct?
Which fuse is responsible for the window motor on passenger's side
It might get unpleasant when it starts raining!
There's a 3inch gap and (touch wood) I hope no one will try to find their way inside.
I will try to take the door card off tomorrow, unless someone's got a solution.
Any help appreciated!
