JMB RetrofitsVolks Autos
Results 1 to 9 of 9
    audi58's Avatar
    Milton Keynes
    149
    Electric Windows not working?
    Just had Ben from Shark Performance replace the dash to a DIS, he managed to get it working, but had to turn the immobiliser off for now as he couldn't talk to it.
    Everything is working fine except for the mileage difference, the word SAFE in above the car mileage, no immobiliser and just found out that the windows don't work at all?
    It has one touch windows all round and they illuminate and you can press the child lock, but none of them actually work.
    Has anyone had a similar problem, or even better a fix??
    I've checked the most common fuses like central conv, any ideas?
    Thanks in advance!
    A7 3.0 TDI 245 S Tronic --Google Maps Navigation Upgrade - Adaptive Lights - Lighting Pack - High Beam Assist - Tinted Windows - DAB Radio
    Previously Owned:
    A5 3.0 TDI 240 S Line -- 3G Navigation
    A4 2.0 TDI 143 S Line -- MMI Navigation - Tinted Windows - DAB Radio - Heated Seats -
    A3 Sportback 2.0 TDI 140 SE -- Remap (thanks to Shark Performance) -- Tinted Windows -- Chrome Roof Rails -- Full Leather Interior -- DIS Retrofit -- RNS-E --
    Brian566's Avatar
    Dec 2009
    70
    DIS conversion
    Hi Just seen your post about your DIS conversion
    I have a 2006 SE which when I bought I did not realise the SE had not got the Drivers information system
    I have asked about retro fitting the unit but realised you have to replace the whole cluster
    Can you advice me of:
    1) were did get the Dash Unit cluster from and what was the cost
    2) looking at the problems did you think its worth it
    I would be realy interested in any comments
    I was also thinking about using shark performance if you have ay other comment you can e-mail me Briant@talktalk.net
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    I just seen a cluster in the adds section
    http://audi-sport.net/classifieds/sh...ct/4416/cat/20
    audi58's Avatar
    Milton Keynes
    149
    Quote Originally Posted by Brian566 View Post
    Sent you an e-mail telling you everything!
    As for that cluster in the classifieds, it's my old one, without DIS!
    Previously Owned:
    Brian566's Avatar
    Dec 2009
    70
    Quote Originally Posted by 54sportback View Post
    Could you please resend e-mail to Briant566@talktalk.net
    Must have had a bit to much last night !!!!!!!!!!!
    Thanks Again
    Khufu's Avatar
    West coast of Scotland
    5,693
    how did he manage to switch the immob off? Didn't think that was possible. I find it odd that windows aren't working. Maybe when coding the were switched off by mistake?
    Diesel one: http://cgi.ebay.co.uk/AUDI-A3-2007-1...item3a56161ffc
    audi58's Avatar
    Milton Keynes
    149
    Yeah, I'm not sure how he managed it, I just want my windows working.
    Could have accidentally done that?
    Thanks anyway
    Previously Owned:
    Khufu's Avatar
    5,693
    In vagcom you can tell the car which modules are fitted to the car by ticking a box. I had to tell the car I had parking sensors after I retrofitted them. Can't remember which one it is offhand (group number 9?). I'd check here in case there is an option.
    27,083
    You have to tell the Can Gateway what modules are installed before you can go into the module, but if the module is fitted & on the can but disabled in gateway then it will show an error anyway to clear, as it sees the can connections.
    I would find it very strange for Ben to miss that problem overall, he seems to be a very competent chap, just give him a buzz & he'll get it sorted for you, but you will need his or your own vagcom to check the codings/modules etc for the issues.
    Its possible in instruments he's missed an adaptation etc, easily done tbh.
Tags for this Thread
