Results 1 to 11 of 11
    Dec 2009
    Birmingham
    88
    Will these rims fit my car?
    Hi
    I'm looking at buying the below set of genuine alloys for my car, the only thing is will they fit my car, as they a width of 245 yet my standard wheels only have a 225 width?
    Part no.8T0 601 025 E
    2007 A3 S-line 170 TDI S-tronic
    Brilliant Red, Bose, RNS-e with bluetooth and SDS multi-function, factory fin, Ipod, Full Vienna Leather, interior ambient light pack, non smoking pack, 18" BBS split rim's, cruise control, 09 vents-climate control-switches, Cupra splitter
    b19ctr's Avatar
    The King of Cannock
    Aug 2007
    Cannock
    634
    thats the tyre width you need the wheel width and the ET to work out if they will fit
    Air, OZ, Tarrox, on a TDI
    NY_Sportback's Avatar
    58
    Quote Originally Posted by M88JCP View Post
    Hi
    if these are from and A5 or a B8 A4 then they will fit but the bore is 66.6 and our cars are 57.1 so you will need centering rings or they will wobble, also the a5 offset is usually around ET33-37 so they will definitely rub on the fenders
    Oct 2008
    Telford
    2,488
    simple answer.......no! A5 wheels dont fit an A3
    Tyres are way to big, even if you change them to 225's the offset will push them out of the arch so will look silly on the A3
    B6 1.8T Avant s line gmbh
    Dec 2009
    Birmingham
    88
    o.k thanks, i'll stay clear of them
    Dec 2009
    80
    Hi! Nice looking rims dude! Anyone knows if you fitt a ET 35 on a audi a3 sportback 2010? I think its original ET 45 or 55. Looks so much better with the rims abit more sticking out Thinking of buying the S3 235/35/19
    Sep 2009
    Finland
    39
    Quote Originally Posted by lundoz View Post
    It's the wheel width and offset that counts.
    ET35 wheel can be more inside than ET50. Just offset number does not tell you anything.
    http://www.1010tires.com/WheelOffsetCalculator.asp
    Check stock width and offset. Then estimate how much there is room to take wheel out. Use calc to check new better size.
    PW-Motorsport's Avatar
    Jun 2006
    Pembrokeshire
    389
    The part number confirms these are from a A5 the spec is
    8.5x19 ET29.
    As correctly suggested above the spigot ring size will be too large @66mm and the offset will be too low.
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,137
    So NO, a NO go.
    Apr 2010
    I am wanting to purchase teh TT version of this alloy for my A3
    I have an A3 (8P Chassis) and I want to put some some TTS alloy on them they are 245/45/18 offset 52 width 9J. Are these wheels to wide? or can I put some 225 tyres on them and squeeze them on?
    help
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,137
    TTS alloys are different, yes you can run a 215 or 225 on it, but you will need a 10mm spacers to clear the struts.
