AH FabricationsChris Nott
Results 1 to 13 of 13
    Dec 2009
    7
    A3 2.0 TDI 54 plate judder/misfire
    For about a year and a half my car has intermittenetly been badly misfiring when idling and more worryingly when I fully accelerate it starts to judder (quite difficult to explain, but something like me trying to accelerate in too high a gear, starts to sort of wheel spin, but if you keep the foot down it pushes on and then drives as normal). As I say it has previously been an intermittent problem, but in the last 3 months is happening on a daily basis.
    One thing I have noticed is that these problems only occur once the engine is warmed up. When starting from cold it runs fine for the first five minutes or so.
    My car is an ex fleet, and has done a rather xcessive 166,000 miles to date.
    Anybody got any ideas, any advice would be greatly appreciated.
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,852
    Have you had a diagnostic on the car? If not i suggest you get one done first,secondly it could be the'flywheel',the wiring loom that runs into the cylinder head,etc.
    Full leather/19"wheels/cruise/
    Dec 2009
    7
    Hi mate,
    Thanks for the response.As of yet I haven't had a diagnostic, but am going to book in next week. When problems first started about a year ago I took it to a Audi specialist here in Leeds, who did a diagnostic on it, but they said that no fault had come up but did acknowledge that there was a misfire and suspected that it might need a replacement fuel injector wiring loom. However as they weren't entirely sure if this was the problem I was understandably reluctant to part with the 140 they wanted to charge to carry out the work. I was actually going to book it in, but a day or two after booking it in I dunked a bottle of redex in my fuel tank and law and behold it started running fine so I cancelled the replacement of the wiring loom. Unfortunately however this fix was temporary and appproximatley 6 to 8 weeks later it returned to its previous less than fully fit state! And at present it is at an all time low, much like my beloved Liverpool FC! YNWA. (I hope my footballing allegiance hasn't deterred any prospective helpers!)
    tdi-man's Avatar
    Jul 2009
    1,589
    mine did this and mines done 170,000 ended up replace the fuel pump on the side of the head.
    you need to check the fuel quantity on idle when warm mine was 2. somethink and now is 4. somethink
    Dec 2009
    7
    I am a complete novice on any motor related issues, so forgive my lack of knowledge, but how do I check the fuel quantity? I assume it's just one of the dials on the dashboard right?!!
    Just out of interest how much did it cost you to sort out the replace fuel pump?
    A3 2.0 Tdi Sportback
    Dec 2009
    Manchester
    20
    I had the same problem on mine but part of the issue was the flywheel. once i replaced the flywheel and clutch its still had and uneven idle but not as bad, so i had it checked for a software update from the dealer and there was one available. They had the car for about an hour and it runs perfectly now.
    Dec 2009
    7
    Quote Originally Posted by Rosario7 View Post
    Thanks again for the advice. Can a software update make such a significant difference? Thats's mad! I have a policy of avoiding dealers, so if I can't get it sorted elsewhere they will be my last resort.
    Dec 2009
    7
    Anybody got any idea on how much I'm looking at to get a fuel pump replaced as it appears that this is the most likely cause of my problems.
    Audi Novice
    Mar 2009
    Suffolk
    381
    Hi Mate,
    I've just had what sounds like the same problem on my A3, was misfiring, on a dual carriage way in 4th gear wouldn't do over 80mph, and was struggling like mad. Put the Redex cleaner in that helped for a week, but then back again. I blamed the supermarket diesel I put it, but after putting it into Audi they had nothing on the diags, but the mechanic had seen this before, replaced the fuel filter, and it's now running perfect!
    Try Changing the fuel filter, they are quite cheap and easy to do. or Audi should do it on your next service!
    Dec 2009
    7
    Quote Originally Posted by TripleD View Post
    Hi Mate,
    Wish it was that simple! Had diagnostic today, misfire on injector 1. All others were fine, going back saturday for definite response as could only plug in computer today and not change injectors around due to time constraints. Anybody know anywhere cheap for injectors as stealers quoting a ridiculous 550!
    tdi-man's Avatar
    Jul 2009
    1,589
    when i tested my car with vag com it said injector 1 was out of tolerance so i had all 4 inhectors changed and i changed the injector loom and it was just the same.
    my probelm was that when i first started my car it would be fine for five mins then once it started to get warm it started to miss but was ok when driving.
    If your not to far from me im in Rugby, warwickshire i can plug vag com in for you and test the injection quantity on idle for you.
    as soon as i changed my fuel pump for a second hand one which cost me 50.00 it was fine and had no probs since over 4 weeks ago
    mine is high milage 170,000 miles and runs like a dream now and i have also been told by alot of diesel experts that the injectors in these cars are very reliable
    theres a set of injectors in the classifieds on this site for 100.00 if you want to get them but they need to be set up correctly which takes a few hours..
    http://audi-sport.net/classifieds/sh...advert-&cat=15
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs / Oil catch can
    233 bhp - 309 ft lb - 419 nm
    FLYWHEEL + HELIX CLUTCH KIT FOR SALE
    Dec 2009
    7
    Smile
    Quote Originally Posted by tdi-man View Post
    Thanks for all the responses guys. I can happily confirm thatmy problems have now been resolved all thanks to a new( very expensive) injector. I'm praying that the other three don't conk out on me now as my Mrs will go inasne if I have to foot another bill like this one!!!!
    Thanks again.
    devonmikeyboy's Avatar
    As far from JBS as possible !
    Feb 2007
    1,257
    If you want any more injectors let me know as i have a few sets laying around.
    06 Audi 2.0 PD140 Sport TDI Quattro S-LINE.
    Old engine 330 bhp @ flywheel 263 bhp @ wheel 490 lb torque. Audidriver write up HERE
    Now stripped and playing with an uprated Cryo treated engine fitted with bigger turbo,water/methanol,uprated injectors etc etc.Wanting 400 bhp and 500 lb torque.
    Other car 500+ bhp MK4 Golf R32 turbo.
