Volks AutosEM Tuning
Results 1 to 7 of 7
Thread: Tyre pressure
    Oct 2009
    41
    Tyre pressure
    gone from 225/45/17 wheels& tyres @ 36psi f /33psi r to 225/40/18 as on 07> sports backs ,should i keep same pressures as the 17's ?
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    Glen
    I run 38psi all round on 18's and i get even tyre war across the width. You will find it rolls better as well.
    S-lines have 18 std and this is my petrol cap sticker
    27,073
    I was told by my wheel supplier to add 2 psi per size up, against what your petrol flap advises for your oem sized wheels
    Oct 2009
    41
    thanks guy's. the exact info i needed.cheers
    Feb 2009
    London
    180
    Quote Originally Posted by paddy View Post
    Glen
    Isn't that for a 3door though? The OP says his is a Sportback, and the tyre pressures for my SB are different to your image.
    Mine are something like 35/30 normal load up to 100kph or 38 all round for max load
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,970
    I have a sport-back and have had the tyre pressure's from a 2.0 tdi sportback (s-line) 225/40/18 38 psi front 35 psi rear normal load or 41 front and back motorway and fully loaded.
    Full leather/19"wheels/cruise/
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    Its only a ball park figure because strictly speaking the pressures are different for different makes of tire. I always run light but 38 all round works well with F1's
