Badger5JMB Retrofits
Page 2 of 2 FirstFirst 12
Results 41 to 57 of 57
  1. #41
    Sep 2008
    London
    50
    One more issue the petrol gauge is also not working...Do I have to change the sensor????
  3. #42
    Khufu's Avatar
    West coast of Scotland
    5,693
    I'm guessing your car is pre-2004? If you read NHNs thread about fitting new white cluster you will see the wiring has changed and you may need a new pump/sender, one that uses 3 wires for the fuel sender not just 2.
  4. #43
    Sep 2008
    London
    50
    Thanks mate
    my car is a 54 (step or oct) one....I have see NHNS thread
  5. #44
    Sep 2008
    London
    50
    Woooooooooo Hoooooooooo it works like a dream oh yeah
    Thanks guys for support
  6. #45
    27,087
    Quote Originally Posted by C39KER View Post
    PS how much do you charge to change the buttons on he SAT NAV to the new style???
    50 plus ur postage costs, its no money spinner but does take time to remove all parts, change test etc etc.
    He done it just as NHN said and it worked fine apart from the abs lights staying on
    Yeap, abs lights up as fault but doesnt show a fault, so have to change as I advised.
    Did you change your pump under rear seat?
    Quote Originally Posted by Khufu View Post
    1 wire for sender iirc, the newer cluster needs 2 wires.
    Thanks mate
    Yes you will need new pump then if your fuel level isnt showing.
    Cool, but what about fuel level?
  7. #46
    Khufu's Avatar
    5,693
    Sorry, what I meant is you need a pump with a sender that uses all 3 wires within the actual pump unit as new one measures resistance on both sides of the pickup point (IE live and two 'earths'). If you dont have that type of pump you will need the new pump & extra wire to the cluster making it 2 wires in total to the cluster as NHN says/did. Dont know where diesel pump/sender 3rd wire goes to as I havent looked at wiring but on petrol it goes to the pickup module.
  8. #47
    Sep 2008
    London
    50
    I just change the complete pump...can't be bored with all that rewiring stuff anyways my car had the up to date wires.
  9. #48
    Mar 2010
    25
    Nobody can provide a detailed description on how to code the new cluster with the VAS machine yet?
    I am dying to install it in my car but I dont want to lose another 100 euros if the guy in the Audi dealer doesnt know how to do it.
  10. #49
    May 2011
    Madrid / Spain / EU
    24
    I'd say you tried to run before you could walk mate, interms of rushing out to get a cluster, some better research may of been advisable to see which facelift cluster suits your A3.
    The S3 cluster is potentially wrong for your A3, you should have got an A3 cluster mate, this maybe the reason why you are having issues overall, but you should have no issues getting the skc out of either given the 8P has the same immo systems from 03 till present day, using VAS, but there's a procedure to follow.
    Hi! I was looking about A3 inmos, how to identify the types used.. and as I understand, you say it's always the same, right?
    I'm not worried about swaping instrument cluster, I would like swap engine ECU...
    I't some long to explain all, but the most important part it's I've a pre-facelift S3, and maybe I have to use a S3 facelift ECU to allow use other equipments..
    I was worried if the inmo were diferent and could have problems matching inmo of new ECU with my instrument cluster
    (something doesn't it's really standard, should be impossible for the dealer!)
    my instrument cluster shows this:
    Code:
    Sunday,22,May,2011,14:30:07:04214
    VCDS Version: Beta 11.2.0
                    Address 17: Instruments
    Control Module Part Number: 8P0 920 931 C
      Component and/or Version: KOMBIINSTR. VDO H20 0570
               Software Coding: 0037118
                Work Shop Code: WSC 06314
                          VCID: xxxxxxxxxxxx
    Advanced Identification
         Serial number: xxxxxxxxxxxxxx
         Identification: VDD-024
         Revision: D0H20004
         Date: 01.02.07
         Manufacturer number: 0765
         Test stand number: 7601
    Flash Status
         Programming Attempts: 0
         Successful Attempts: 0
         Programming Status: 00000000
         Required Conditions: 00000000
         Flash Tool Code: 00000 000 00000
         Flash Date: 01.02.07
    Misc.
         Hardware number: 8P0 920 931 C
         Lot Number:
         Type Lock:
    Car Info
         Chassis Number: WAUZZZ8Px7xxxxxxx
    VCDS Info:
           Labels: 8P0-920-xxx-17-MY7.lbl
    and here it's an instrument cluster from S3 facelift "white fis":
    Code:
    Wednesday,18,May,2011,20:05:12:04214
    Control Module Part Number: 8P0 920 932
      Component and/or Version: KOMBIINSTR. VDO H15 0820
               Software Coding: 0069128
                Work Shop Code: WSC 03328
                          VCID: xxxxxxxxxxxx
         Revision: D0H15004
         Date: 02.06.08
         Manufacturer number: 0700
    Flash Status
         Flash Date: 02.06.08
    Misc.
         Hardware number: 8P0 920 932
         Lot Number:
         Type Lock: VDD-
    Car Info
         Chassis Number: WAUZZZ8Px9xxxxxxx
    VCDS Info:
           Labels: 8P0-920-xxx-17-MY8.clb
    it's the same inmo type? both shows the same type of codes of Inmo4 challenge in ECU module
    both clusters shows "VDD-024", it's a type of inmo? I heard there are different type of inmo4
    thanks in advance!
  11. #50
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,388
    Quote Originally Posted by spanishpacs View Post
    I am dying to install it in my car but I don�t want to lose another 100 euros if the guy in the Audi dealer doesn�t know how to do it.
    With the amount you have spent you may as well take a road trip up to the UK and have the people that sorted out NHN and N8. you can get your car sorted and have a nice holiday
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Interior Lights Pack
    MODS:
    S3 facelift,
    RS3 Grill, 19" RS6, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, Auto Folding & Dimming Dumbo Mirrors, S3 brakes, US Centre Console, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
  12. #51
    27,087
    Quote Originally Posted by berto View Post
    Ok 1st tell us what new features are you wanting to get on the newer ecu?
    IMMO should be identical, given newer clusters have been fitted into cars that are 6yrs or so older.
  13. #52
    Sep 2010
    9
    Hi does any one know any dealer in the midlands area that can programe these clusters ????.Coventry AUDI are a waste of time.
  14. #53
    Nov 2010
    Hi nhn have also bought new 2011 s3 clock cluster and needs coding will your vagcom work for this or will i need vas5054?
    thanks
  15. #54
    Feb 2014
    Hello, I don't know how to conect the new fuel pump. Any help?
    Thank you
  16. #55
    27,087
    Welcome to the forum.
    Do your research please, its been discussed number of times on various forums, so you need to search & read.
  17. #56
    Feb 2014
    I found it, but the message is something like I have no permision to see that information.
  18. #57
    Feb 2014
    Any help please?
