Results 1 to 7 of 7
    Oct 2009
    99
    OEM SACHS OR SRE ORGANIC SACHS ????
    Im in a bit of a dilemma and just after a few opinions to finally make up my mind on what to do.
    Basically my S3 is mapped to approx 310bhp,im gonna get it re-done by Star performance in new year with the GIAC software and make it switchable.
    Apart from maybe getting a ITG induction kit in the future thats gonna be my limit on the tuning front.
    Here's the dilemma.....my clutch is slipping,its a 2007 car so guessing its the Luc clutch, will i get away with a oem sachs one from audi (and flywheel) or do i need the Organic sachs clutch.
    Im swaying towards oem ??
    Your thoughts would be appreciated as i really need to get it sorted !!
    Thanks in advance.
    Mar 2008
    Bradford, WY
    788
    Organic mate! Atleast then if you want you can tune further you can! If not it will last longer than oem. Theres a group buy for sre organic, see group buy section. Sre clutch and flywheel is lighter than oem!
    A3 2.0 TDI Optics Black S-Line, FR&RTuning Stage 3! GT20 Hybrid Turbo, THS TFSI FMIC, Sachs performance clutch kit+SMF, Milltek 2.5" Turbo-Back Non-Res Exhaust, ITG Maxogen Induction, EGR Delete with FR&RTuning Map out, Custom Black 18" RS4, 35mm H&R springs, S3 brakes, EBC Yellowstuff, front splitter, HID Xenons, S3 tailgate Spoiler, 09 Rear Lights, Retrofit Audi Ipod, S3 Air vents, Bose sound+retrofit JBL Subwoofer 1200W.
    Milltek Cat-back Non-Res for S3 2.0T FOR SALE both 3dr and 5dr PM
    david_phillips95's Avatar
    Nov 2008
    538
    Quote Originally Posted by navnayyar View Post
    Is it a single mass flywheel? if so i would not advise running these, a few guys on here have had issues with them plus they produce alot of transmission noise at idle (sachs even have a note on their site about this when purchasing). Great for a track car for everyday road use not so great.
    I have the Sachs Perfromance Clutch sitting in my room, once i go stage 2+ then i will probably fit it. At the moment running stage one the clutch is doing OK if i sit in 5th at 3k RPM and floor it i can get it to slip ever so slightly but this is me trying to make it slip. Driving normally i have had no issues (touching wood ).
    The Sachs Performance clutch costs around 600, i bought mine direct from Sachs, as they deal in euro's it depends on the exchange rate how much your going to pay.
    Some pics of the Sachs Perfromance Clutch
    Cheers Davie
    Oct 2009
    99
    Thanks both for your replies,i will go for the oem dmf if required i just cant decide on the clutch i dont want to waste money on the organic one if i dont really need it my car has done 54k on the Luk clutch 10k re-mapped......decisions decisions !!
    Are you running the oem sachs at present Davie ??
    Nov 2008
    538
    im still running the clutch that has been installed from new not sure what will be installed as mine is a 2007 also, my car has done around 18k miles and about 1k remapped. If your not planning on going above stage 1 i would say the OEM Sachs clutch would be fine as it seems to cope with the extra torque produced when remapping. If you wish to go stage 2 or stage 2+ a performance clutch will be required to eliminate clutch slip.
    Cheers Davie
    Iggu's Avatar
    May 2008
    Here
    1,224
    Phantom Black S3, RNS-E with SDS Hack , BOSE, Sunroof, iPod, ITG CAI, Forge DV, Milltek TBE, Revo Stage 2+, Autotech HPFP, Sachs clutch, Lamin-X, BBS Pescaras, H&R springs, H&R ARBs, NGK Iridium Plugs, Vagcom.
    Phil_T's Avatar
    Revo Stage 2+ Audi S3
    Oct 2009
    236
    So with stage 2 & stage 2+ do you need just a clutch upgrade or flywheel too?
    If so are these the only things I would need?
    SACHS Performance Cover and Organic Plate
    OEM Slave / Release Bearing to use with above
    Revo Stage 2+ - Miltek Non Res Turbo Back Exhaust - Evoms Intake - Autotech Fuel
    Pump - Forge DV - Sachs Clutch - BSH Engine/Gearbox Mounts - BSH PCV Mod - RS4
    FPR Valve - Airlift Performance Struts With Adjustable Top Mounts & Droplinks with Accuair Management - H & R Anti Roll Bars - 42 Draft Designs Shifter Bushes - BBS E28 Magnesium Motorsport Wheels - Piano
    Black Optics Grill & Fogs - Piano Black Door Mirrors - Carbon Fibre Front Splitter & Rear Diffuser
