Chris NottVolks Autos
Results 1 to 29 of 29
    chrissy1502002's Avatar
    Portsmouth'ish
    247
    Buying a 2.0T Quattro
    Good morning all,
    this is my first post and its for a bit of advise, I am going to view this car tomorrow:
    http://www.churchsperformancecars.co...p?StockID=1001
    I have the intention of putting a deposit down on the car, as it looks like exactly what ive been looking for.
    Is there anything that you guys and gals would recomend me looking for?
    Regards
    Chris
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Welcome to the forum! That car is almost identical to my old A3 and it was a great car. I can't think of anything specific that goes wrong on them as mine was flawless for the year I had it. I'd say make sure you give it a full function test though. These cars have a few toys and it's worth spending some times checking that the air con works (even in this weather!) check the DIS doesn't have dead pixels, every function on the stereo works etc etc
    8P2 S3
    smudge_don's Avatar
    Dec 2008
    Sutton, Surrey
    2,941
    Personally, i wouldn't buy it with 74k on the clock
    Currently driving a 55 plate Ford Mondeo ST. But as Arnie once said...
    I'll be back!!!
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    For the right price I would. Less than listed of course. Also the list on the right says metallic paint and it says solid in the write up. You could only buy solid black or pearlescent (Phantom) black at that time.
    8P2 S3
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,814
    You seem to be missing the cigarette lighter :P
    You need an armrest as well - a must have!!!
    smudge_don's Avatar
    Dec 2008
    Sutton, Surrey
    2,941
    Obviously i don't know your situation Chris, but if you have a budget in mind, i would look for something with a little less mileage
    Don't get me wrong, it's a lovely car and i'm sure it's been looked after, but for buying such a nice car that has done 75k in just under 4 years seems a bit high to me
    I'll be back!!!
    Portsmouth'ish
    247
    Firstly thanks for all of your inputs.
    I have had a look in the Glass's guide, and it books at around 10,000 so that is the money i will be aiming to spend at a maximum.
    The milage is high for the age of the car, but from my experience with my Seat Ibiza Cupra, servicing is the key. I used to work for Portsmouth Audi and we had cars come in with alot more miles, but i doo take your point on board.
    I was not sure of the mechanical side of it, as i say i used to work au Audi, but at the time the A3 was still relitively new, and they didnt have many problems. I was just wandering if any had materialised over their life?
    Also do you think that the standard clutch will be ok with an AMD remap?
    Chris
    Boydie's Avatar
    Boycie
    Dec 2006
    4,814
    The clutch should be fine with it but you have to take into account that the car has done 74k on the standard clutch with standard map so there will be wear and tear. Adding more boost and torque to the car will increase this but depending on you driving style, I think it will be ok
    My TDI A3 had a map on it for 60k and its still going strong!
    Portsmouth'ish
    247
    Thats a releif, my Cupra has now just ticked over 80k and has had a stage 2 remap from about 30k and its fine so far, i had read about the S3 clutches having some issues after a remap, and just was unsure about the normal A3
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    Very similar car to mine, high mileage is off putting but if its been looked after then high mileage isn't a problem. remapped i reckon the engine will be running 240ish bhp, don't worry about the clutch too much, they can take some abuse but then again saying that it all depends on how its been driven.
    things to look out for are the usual car stuff like the car not pulling to one side etc.
    if you get chance turn the ESP off and boot it in 1st from stand still to make sure the quattro system is working, its not uncommon for rear diffs to pack up and not go into 4wd.
    check the wear on the discs and pads, if they are worn its a good bargaining point to get money off as thats yet another 200 to change those, same goes with tyres, at 130 a corner it can get expensive, also make sure that all the tyres on the same axle are the same brand and have the same wear rate, the quattro system is quite sensitive to uneven tyre wear as it wears out the diff.
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    ah one more thing, when the car is at stand still go lock to lock on the steering wheel and listen out for creaks, its a common issue for steering columns to start creaking, i had mine done under warranty a couple of years ago and now the creaking is back, not going to bother fixing it as its a good few hundred quids worth of work!
    Portsmouth'ish
    247
    Thanks Robin, thats exactly the sort of things i was after.
    Do the tyres need to be the same on the front and rear, or just on each axel?
    Brilliant Black A3 2.0T S-line Quattro Special Edition. S3 front brakes, Turbo back Milltek including race cat, APR Intercooler, Evoms air intake, AMD Stage 2 map, Upgraded OEM DV, Sachs Race Clutch, SMF conversion, Forge short shifters, S3 wing mirrors, S3 Rear end, Interior LED conversion, Bi-Xenon's, LED DRL's, BBS CH's, MY 09 Rear lights, Full leather, Tinted rear windows, Custom black front grills.
    antmax7's Avatar
    sheffield
    300
    paid 12,500 for my sport back three months ago and mine has loads of extra's and only 22k on the clock look around fella. there is plenty out there better than that one for the money!
    cameron1's Avatar
    Mar 2009
    56
    Reading through the small print, this car already has an amd remap with milltek exhaust, so the clutch and turbo have not been running on standard power.
    I think it is a bit overpriced with that mileage, got my 55 plate from a private seller with 34k miles (basically same as this) back in March for 10k, although I guess prices are going up.
    2.0Tfsi Quattro S-line + remap
    Oct 2008
    Telford
    2,488
    Them tailpipes look filthy for 2 months old!
    B6 1.8T Avant s line gmbh
    Aug 2007
    Swansea
    82
    Quote Originally Posted by chrissy1502002 View Post
    When I got my tyres changed (Under the Audi Service Care plan) Audi finance specifically told the garage to change all 4 tyres even tho there was plenty of tread left.
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    same on each axle.
    they should ideally be changed all 4 at the same time, mine seem to wear all at the same rate so i change all 4 at the same time.
    May 2009
    Birmingham
    95
    you say you think you're going to view a Quattro yet I cannot see the word Quattro mentioned in the advert?? Looks like a FWD 2.0TFSI to me...
    Collected 14 July - 2009 MY10 A3 1.9TDIe Sport 3dr in Brilliant Black
    Factory options: Cruise Control, Debadged, Chrome Exhaust tips
    Mods: CC Tuning remap.
    Aug 2005
    West London
    850
    Just change the tyres on each axle at the same time. Some 4wd cars(I think it was evos that had the problem) have known to wear the centre diff with different age/worn tyres but thats not common and the A3 doesnt use a centre diff so it makes no difference. Keeping the same age/type of tyre on each axle keeps the car balanced and predictable.
    Now:BMW 530d M-sport tourer. Then:Lava Grey A3 Sportback S-line 2.0TFSI Quattro, S-line Special Edition, Xenon Plus, Leather, Light and Rain Pack, Interior light Pack, Bose, DVD Nav+, Bluetooth, Multifunction wheel,Cruise, Heated Front Seats, Folding Mirrors, Rear Parking Sensor and some other bits.
    V6Pete's Avatar
    Now running on Bentley's y'all
    Feb 2009
    Northants
    1,492
    Quote Originally Posted by Dandle View Post
    I was always advised on both my previous "proper" 4wd cars to change the tyres at the same time. Cavalier Turbo and S4.
    The Cavalier's were prone to wrecking the transfer box if the tyres weren't within a couple of mm of each other.
    A3 3.2 V6 S-Line | Brilliant Black | Full Votex Kit | 18" Cades Bern / 19" Bentley 5 Spokes in flat grey with 215/35 Falkens | Custom Code Remap
    V-Maxx coilovers | Remus exhaust | Pipercross Viper | Goodridge Brake Lines | RNS-E | Bluetooth | FBMFSW
    Previous VAGs: 99 S4 Biturbo | 06 Golf GT TDI | 08 A4 S-Line TDI PD140 | 02 Passat 4.0 W8
    Other toy: Suzuki GSX-R750 K3 Black/Silver
    Leather arm rest for sale | S3 mirror covers for sale | 09 3dr tail lights wanted | Twin grills wanted PM me!
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,047
    Chris
    The clutch and DMF failed on my Golf after a remap (same Engine as A3 20TFSI 200ps) and had done less than 20K miles.
    Obviously not all cars are afflicted but knackered clutch/DMFs on VAG 20TFSI is certainly not un heard of.
    You will probably see more evidence of this on the Golf forums as there seems to be more tuned MK5 Gtis kicking around than 20T A3s..
    cheers
    Paul
    Now:
    -MK2 Golf Gti 16V/VR6, Oak Green, Shrick, Intake, Decat, Kish Retrim, Lenso BSX..
    -BMW 335d Xdrive, Estoril Blue, fully loaded.
    Before:
    S3 (8P), Ibis, DSG, Milltek, SHARK
    BMW 320d M Sport
    S3 (8P), Sprint, REVO, H&R Springs, BBS CHs,
    Golf MK5 GTi 20TFSI - REVO Stage1, Red.
    Golf MK5 GTi 20TFSI - Std, Shadow Blue
    Civic Type `R`
    Golf MK4 GTi 18T - 200bhp, MTM ECU, Forge DV
    Golf MK3 VR6 - Cat Back
    Corrado VR6 - JAMEX
    Corrado G60 - JAMEX, BRM Charger rebuild
    etc....
    MG
    Aug 2009
    137
    Definitely check the air-con as Staz has already said. The compressor is a known weak point and is expensive to fix.
    _________________________
    2005 A3 2.0T S-Line Quattro, Phantom Black, Superchips remap, H&R 35MM Springs, S3 brake upgrade, lamin-x, full MV exhaust, 19" anthracite Sportec Mono 10s.
    mikep's Avatar
    Jun 2003
    Wetheringsett, Suffolk
    591
    No, it's not a Quattro.
    Pragmatik ICT
    Revo (VAG & Porsche) & Steinbauer Dealer for Suffolk & N.Essex
    A3 Sportback 2.0TDi Sport DSG Revo Stage 1 & 2
    Porsche Boxster S Revo Stage 1
    mikep's Avatar
    Jun 2003
    591
    .....and it's very expensive for a car with a declared remap and go-faster bits.
    Pragmatik ICT
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    i thought you could only get 2 models in the 2.0TSFI:
    2.0TFSI with DSG - 2WD
    2.0TFSI with 6 speed manual - quattro
    didn't realise that they did a 2wd 6 speeder.
    May 2009
    Birmingham
    95
    Quote Originally Posted by RobinA3 View Post
    http://www.parkers.co.uk/cars/review...03.aspx?page=7
    it's the 2.0TDI 170 that is limited only that you cannot have DSG box with Quattro. But FWD either manual or DSG.
    the 2.0TFSI or whatever guise it is 2.0T etc can be in the four transmissions and I wasn't aware the turbo charged 2.0T came with less than 6 gears? even the 2.0FSI came with 6...
    on a new A3 though you can't get manual box with Quattro with 2.0TFSI...
    Confusing or what!!!
  28. #27
    Portsmouth'ish
    247
    Thank everyone for your help. I went and had a look at the car, and it is Quattro. It also has got S3 front brake's, with brand new disks and pads. Its service history is all from Awesome GTI and it was last done in August of this year. There were a number of advisory's and the garage have agreed to repair all of the advisory's.
    The car felt like new, and still felt relitively tight. The Quattro system works perfectly and it drove fantasticly.
    I shold be picking it up within two weeks, as long as i can sell my current Ibiza Cupra.
    Once again thanks for all of your help!
    Regards
    Chris
  29. #28
    Aug 2005
    London
    263
    Hope you got a good price - looks like you've got yourself a nice motor there!
  30. #29
    Portsmouth'ish
    247
    Thanks! Yeah, I feel that I got a good price so im well happy. Like i said, the garage hadnt noticed the S3 brakes on the front so another bonus
