AH FabricationsVolks Autos
Results 1 to 7 of 7
Thread: Headlamp washer
    stealth64's Avatar
    Oct 2009
    West Mids
    233
    Headlamp washer
    Anyone know how i use my headlamp washers? my xenons are covered in grit and crap off the roads and need a quick blast and I cannot find switch/button/knob/handle or whatever i use!
    sorry for the thread but tried a search and couldn't find owt!
    Ride: 520d M Sport Cobolt Black, 19" Spyders
    Previous rides:
    2.0T Quattro S-Line
    Lava Grey - Sportback
    Aug 2005
    West London
    850
    They work automatically when you do the windscreen washers and the headlamps are on. I'm not sure if they work everytime after the first blast since the lights are turned on or every 5th one like BMWs though.
    Now:BMW 530d M-sport tourer. Then:Lava Grey A3 Sportback S-line 2.0TFSI Quattro, S-line Special Edition, Xenon Plus, Leather, Light and Rain Pack, Interior light Pack, Bose, DVD Nav+, Bluetooth, Multifunction wheel,Cruise, Heated Front Seats, Folding Mirrors, Rear Parking Sensor and some other bits.
    stealth64's Avatar
    Oct 2009
    West Mids
    233
    Thanks probably just not noticing it happen then, will get someone else to do it so I can watch!
    looks like your old car was the same as my current one, why did you change?
    Previous rides:
    2.0T Quattro S-Line
    Oct 2009
    North West UK
    56
    You need to hold your windscreen washer jets on for 2 or 3 seconds for the headlight washers to activate. This allows you to give the screen a quick squirt without washing the headlights every time, which would otherwise use up your reservoir very quickly
    Mar 2009
    Staffordshire
    1,199
    Quote Originally Posted by stealth64 View Post
    I'd say it's pretty easy to notice the spray, so you'd probably see if it's doing it.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    Yeah a big mist appears at the front of the car. I have changed the delay between washing the windscreen and the headlamps on my car as I was getting through washer fluid like nobody's business last winter!
    8P2 S3
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,775
    I used a hell of a lot of water this morning so will have to check the levels later when I am home!!!
