Sky InsuranceChris Nott
Results 1 to 8 of 8
    A3 2.0 Tdi Sportback
    Dec 2009
    Manchester
    20
    Rear window wiper not working
    Hi everyone,
    yesterday while de-icing my car, the rear window wiper suddenly stoppped working. i've checked the fuse and its still intact, so i left it for a while in case it had frozen but still nothing. Is this a common fault?? is there anything else i can check before considering a new motor?
    smudge_don's Avatar
    Dec 2008
    Sutton, Surrey
    2,941
    If it's not the fuse, then it must be the motor mate
    Currently driving a 55 plate Ford Mondeo ST. But as Arnie once said...
    I'll be back!!!
    Mar 2009
    West Yorkshire
    118
    sorry to hear that mate, a quick question, my back wiper is working, but the water doesn't seem to come out anymore once it was finished, i've top the water level up and the front wiper squirts fine, but the back one doesn't.
    Any advice/hints/tips???
    Audi A3 (2005) 2.0 TDI Sport Quattro (140/ST3) 8P2
    RNS-E (2009 Map) & Cruise Control Installed!
    Dec 2009
    Manchester
    20
    a sagad Its probably the jetta holes are clogged up, have u tried unblocking the holes witha needle? u can purchase the actually piece for next to nothing i changed mine not so long ago.
    ok, thanks for my reply smudge dog, now, does anybody know how much a new motor is??
    Apr 2009
    Hey,
    Mine did the same last week when it was really cold. It then started working again when the weather got slightly warmer. Then this morning with the car covered in snow it stopped working again. About 30min later on the way to work I tried it to see if it would start to work and it started to wipe but only got 1/3 of the way and stopped again. Not sure what it will be but just seems a bit odd that its only not working in the very cold weather.
    By the way, first time posting but been following this forum for a while and its great.
    Thanks guys.
    Dec 2009
    Manchester
    20
    Thats pretty much whjat happend to mine Nylon39.
    But, i have just finished speaking to a friend who works at audi and he advised me to check the connection first and see if they are all tight and secondly he advised that the wire breaks on the near side loome on the hinge. ill check it out tonight and let u know the outcome.
    Khufu's Avatar
    West coast of Scotland
    5,693
    Quote Originally Posted by a_sagad View Post
    also check if the water is dripping out of the tailgate etc. The pipes have been known to pop off due to frost. When you use the washers it just runs out the end of the pipe, often into the tailgate area.
    Mar 2009
    West Yorkshire
    118
    Khufu - I'll have a check today when I get back home.
