Chris NottVolks Autos
    Dec 2009
    Starting problem
    hi all could really do with some help. i recently couldnt start my a3 was told it was the starter .... had it changed still couldnt start .......... so i put a connection from starter just a wire and i touch the battery with other end of wire then it starts no problem >>> i changed the plug to the starter still no joy..... ive checked all connections and cleaned them up my barrel in ignition is good as it turns and pops back correctly anyones advice would be welcome . as to start it is a hole process i could do with out ????????????????????????????????????????????
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    Have you checked fuse F15 under the bonnet in the fuse box
    Khufu's Avatar
    West coast of Scotland
    5,693
    I'd check the starter relay too.
    26,716
    Did you resolve your issues Ashbee?
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    id guess so nige else surely by now his battery would be flat mate.
    LOTS DONE, LOTS SPENT !!!!
    26,716
