Badger5AH Fabrications
    Kingston's Avatar
    Jun 2009
    Preston
    182
    Split turbo pipe?
    How can i tell if my car has a split turbo pipe? lots of wooshing sound from turbo but no power.
    Nogaro Blue 2001 S3 Quattro, Cream leather interior. Miltek Cat back, Induction kit, KO4 Hybrid Turbo, Chipped Remap, Power Boost Valve, Forge RC DV, Compbrake Racing 4 Pot Calipers with 2piece 350x32mm Conversion Front, 2 piece 330x20mm Compbrake Conversion on Back, Discs are Powervane Racing Rotors Gas slotted and internally veined. Hawk Hps Pads, Goodridge Braided lines to Calipers. Bose Symphony sound system. Compbrake Quickshift and side shift. Big thanks to www.Vagperformance.co.uk
    david_phillips95's Avatar
    Nov 2008
    538
    a boost gauge or vagcom should be able to tell you what your boosting, if it is substantially lower than normal you know the boost is escaping or is not being generated e.g faulty turbo, split/loose pipe etc.
    Davie
    Mar 2008
    Bradford, WY
    788
    How do you test boost pressure in vcds? Iv got the latest one but still getting used to how to use it full. what settings is it under? Thanks
    A3 2.0 TDI Optics Black S-Line, FR&RTuning Stage 3! GT20 Hybrid Turbo, THS TFSI FMIC, Sachs performance clutch kit+SMF, Milltek 2.5" Turbo-Back Non-Res Exhaust, ITG Maxogen Induction, EGR Delete with FR&RTuning Map out, Custom Black 18" RS4, 35mm H&R springs, S3 brakes, EBC Yellowstuff, front splitter, HID Xenons, S3 tailgate Spoiler, 09 Rear Lights, Retrofit Audi Ipod, S3 Air vents, Bose sound+retrofit JBL Subwoofer 1200W.
    Milltek Cat-back Non-Res for S3 2.0T FOR SALE both 3dr and 5dr PM
