Sky InsuranceChris Nott
Results 1 to 8 of 8
    tspar's Avatar
    Dec 2009
    24
    Audi's quattro v VW's 4 Motion....
    Having just traded in my R32 for an S3 im noticing that the S3 has wheel spun in first a few times. Am i correct in thinking that the quattro puts it all through the front wheels until it decides that the rear needs a bit of stability and therefore isnt "True 4 wheel drive" in the same way as the "4 Motion" system is?. The R32 never once spun in the five years i had her.
    Can anyone with "Knowledge" of these things clear this up for me please?
    Tim
    Silver '07 S3 - Practical, good looking and goes like stink !
    Previous mota's of note:
    Golf V6 4 Motion
    MK 4 .:R32
    beanoir's Avatar
    Sharpest Tongue in the West
    Jan 2007
    51 Degrees North
    2,173
    given that the systems on the 2 cars you've mentioned are essentially the same (Haldex) although depending on which age each the cars were, could be slightly different generations of the Haldex, I reckon it's more likely to be the fact the weight of you old V6 on the front wheels helped prevented them spinning in the R32 as much as then lighter engine in the S3.
    Thats my starter for 10
    Porsche Cayman S |Jeep Grand Cherokee|1988 Ford Fiesta XR2
    www.essexdriversclub.com
    Sep 2005
    Worksop, Notts
    97
    tspar, long time no see Will drop you a PM.
    As beanoir said, the systems are very similar (infact the S3 system is a newer revision and in my opinion better). If you think there may be a problem with the 4wd system try leaving your handbrake on the first click and pulling away quickly, you'll soon see what proper wheelspin is!!
    tku
    tku's Avatar
    Sep 2009
    639
    Yes..But which ones faster?
    NY_Sportback's Avatar
    58
    I would say tires before anything else since they are the same system except for the S3 is the better more updated version(wouldn't rule out engine weight either
    DeckedS3's Avatar
    Apr 2008
    South East
    550
    Quote Originally Posted by tspar View Post
    Tim
    Ah ha! Did you used to post on tyresmoke?
    IIRC, you had a silver R32... Good choice with the S3!
    Meteor S3, APR Stage 3, APR HPFP, Milltek TBE, LOBA/Sach's Clutch, Bilstein PSS10's, H&R ARB, Gen4 Haldex PP, EVOM's DV & CAI, Forge TB with Pro-Alloy IC, BBS CK 19" My S3
    Aug 2009
    169
    More power and lighter front end, though i've never had big wheelspin from an 8p s3 so could also be bad tyres
    S3, 4 wheels, magical B8's, Eibach, Pipewerx equipped, glass windows, metal engine, silver paint.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    Could be the tyres also
    8P2 S3
