Monster MotorsportEM Tuning
Results 1 to 25 of 25
    Living a little!
    London
    181
    Problem fitting Ashtray Delete- HELP!
    As Above,
    I ordered the part but seems to be too wide. Am I doing something wrong?
    Its as if it tucks under the side plastic to make flush but cant see there beeing enough room, am I to cut the sides off?
    I have tried getting the side plastic trim off ( triangle handle trim) but cant seem to get it off, I have unbolted the 2x bolts where is the other?
    Thanks in Advance.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    You need to remove the grab handles mate. You'll find a bolt on each towards the front under the console, a bolt at the rear under the gear stick gaiter and then a bolt at the apex of the handle at the top.
    Once the handles are off the tray pops in and the handles go back on making a nice flush fit.
    8P2 S3
    Mar 2008
    Campbeltown
    9
    You shouldn't need to remove the grab handles, (well i didn't when i fitted mine) the side bit should just push in.
    Audi S3 Black edition
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    no chance! The grab handle overlaps the top of the tray!
    8P2 S3
    Living a little!
    London
    181
    Yep had to take the grab handles off screw under console, very very awkward!! Lost the bleeding screw and bit, went down the back and gonna have to take the whole centre console out tomorrow as run out of time and is a bigish job, need the car to get to work at 1pm.
    Thanks all, made it so much easier.
    4NT
    4NT's Avatar
    Terminal Douche Bag!
    York
    369
    Just a quickie, how much did the part cost? Think I'd like to do this too.
    Living a little!
    London
    181
    Quote Originally Posted by 4NT View Post
    From memory its 9.50 or about. Bargain!
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    indeed it is and grab handles deffo need to come out, its all a bit fiddily but works fine in the end, i love the extra space
    4NT
    4NT's Avatar
    York
    369
    Cheers, got a contact there and I can get the rubber dimple tray thing for relatively cheap but they said I need loads of other bits of trim, sent me the full diagram, couldn't figure it out. I only want some place to stash my phone!!!
    What's the verdict, 1 part sub 10 or loads of little bits coming to +50??
    Cheers.
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    you only need the one bit the othe bits are for the cig tray.
    Living a little!
    London
    181
    Cheers.
    All you need is the 1 Part. Part Number is on here somewhere.
    aristides's Avatar
    Aug 2008
    Greece
    543
    Does anyone got the part number for this small trim? I would like to do the ashtray delete myself, since i`m not smoking -at least in the car - and i need a place to put my junk!!
    FOR SALE:
    RNS-e 2013 DVD, BK Version, NOT unit, DVD disc
    Steering ECU : 1k0 953 549 AH, ideal for Cruise Control retrofit
    jameo84's Avatar
    Sep 2009
    east kilbride
    123
    id also like the part no. thanks.
    Khufu's Avatar
    West coast of Scotland
    5,693
    its 8P0 863 301 A 4PK for black and if you unlucky enought 8P0 863 301 A 6G6 for blue...
    jameo84's Avatar
    Sep 2009
    east kilbride
    123
    were is best to get one from? stoke audi?
    Khufu's Avatar
    5,693
    East kilbride? Not too far from me. You could get 10% of at Stoke IIRC being a sponsorer but by the time you factor in delivery on something circ 10 it might be worth a visit to your local dealer - the other half can visit Braehead while your there LOL
    jameo84's Avatar
    Sep 2009
    east kilbride
    123
    cool i just pop in the next time im out that way. thanks
    geraint.davies's Avatar
    May 2009
    48
    If this is fitted with the brushed silver trim, is the tray still black?
    Sorry if this is a silly question!
    27,099
    The other parts would be the trims that go above the rubber storage part, that fix to the underside of the climate control, there's a trim or 2 & also they tend to have the led strip that goes under there aswell to light the area up if you have the interior light pack, you dont need this lot, but I personally think it finished it all of nicely & those handles 100% have to come out to fit incase you are thinking of a quick fix.
    27,099
    Quote Originally Posted by geraint.davies View Post
    Well if you think a silver tray looks good then I'll supply & spray it for yer, (nottttt), lol, nah mate the rubberish tray is black.
    aristides's Avatar
    Aug 2008
    Greece
    543
    NHN do we have also these parts? I mean the led stripe that is fixed under the climate unit. It would be nice to complete the interior light pack, since i already did the doors and the map lights.
    A while ago i found a guide in a german forum , but i cant seem to locate it again!
    FOR SALE:
    May 2009
    48
    Resurrecting an pld thread, having the same problem, don't seem to be able to find/undo the third bolt on the grab handle, have undone the one by the gearstick and the torq one at the apex of the handle, just can't get to where the third will be, what trim needs removing?
    Any help much appreciated as the car is currently in bits!
    2008 Ibis White S3
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    theres one on the underside of the grab handle mate
    May 2009
    48
    Its ok, sorted it now.
    2008 Ibis White S3
    May 2009
    48
    Quote Originally Posted by P5SND View Post
    Didn't see this, was outside, managed to work out it out.
    Cheers anyway.
    2008 Ibis White S3
