Volks AutosMonster Motorsport
Results 1 to 7 of 7
    Dec 2009
    Can you help a newbie with some retro-fits?
    Hi guys, great forum with lots of info which I promise I have searched!
    I have 2009 A3 cabrio and wish to retro fit cruise, MFSW, BT and RNS-E.
    Can you experts confirm the following?
    Cruise needs a new lower cowling and switch?
    BT needs module, antenna, mic and wiring harness?
    MFSW is straight swop with original wheel (3 spoke airbag)?
    RNS-E (to be done when funds allow!) is straight swop? (I'm aware of antenna issues which may appear)
    Now as I dont have cruise or MFSW at the moment I guess I need a new steering ECU? (SCSM?) Does anyone know which part number ECU I need to support cruise and MFSW? I see from searching the main part number is the same but the suffix letters differ, which ones will do the trick?
    And lastly, might I need to change the slip-ring behind the steering wheel for the mutlifunction to work? What part numbers are good? I know VCDS coding changes are also needed.
    Thanks in advance guys!
    evapor8's Avatar
    Jan 2009
    Guernsey, Channel Islands
    463
    I'd take the easy option mate and get either OEM Retrofits, TCL Sat Nav or Hazzy Dayz to fit them for you (depending upon where you live.)
    Chris
    NB: That's assuming you're lazy/ham-fisted like me, and can afford them.
    Car: Phantom Black A3 2.0 TFSI S-Line BLACK EDITION, 3-door, manual
    pns2007's Avatar
    Nov 2008
    627
    Hi Chris, I used to have an A3 cabriolet and retro fitted cruise and RNS-e amongst other things. Do you have VDS or know of anyone with it? You will be able to find out the part number for your steering wheel control module, otherwise a telephone call to Audi parts with your reg number and they will be able to tell you. Once you know this it will be the starting point for cruise and perhaps the mfsw interface.
    Cruise was a couple of hours to do, you will need the stalk and lower cowling. If your careful you can cut and file your existing cowling.
    RNS-e is an easy retro fit.
    Having read threads on here, the steering wheel should just swap over but need to check the air bag, there were issues regarding the air bag but I think this was on earlier models, but check before you buy one.
    Whereabouts in the world are you? I could help out if needed and have VDS.
    Neil
    ps you don't want a wind breaker do you for those colder days with the roof down?
    2013 A5 2.0 TDI (177) Black Edition
    [s]2012 A1 1.4TFSI (185ps) Black Edition[s]
    [s]MY2010 A4 1.8T (160) S-Line executive in brilliant Red[/s]
    [s]2008 A3 TDI S-Line Cabriolet 8P3[/s]
    A4 (B8) Door warning light and Glovebox retrofits. A1 Heated Mirrors Retrofit
    Dec 2009
    Quote Originally Posted by evapor8 View Post
    Chris
    Have you seen how much they charge?! Yes I can afford it but thats not the issue, it doesnt seem that hard once I get the right parts so I will have a bash.
    Quote Originally Posted by pns2007 View Post
    Yes I have VCDS, not the car at the moment though. Does anyone know the right SCSM part number I need to support cruise and MFSW? Someone must've tackled this?
    pns2007's Avatar
    Nov 2008
    627
    Hi Chris,
    check out this post with regards to the correct stalk part number
    Quick question for anyone with a new 2009 A3
    and this for the steering wheel control module
    http://audi-sport.net/vb/showthread....cruise+control
    If you use search you will find the answers to most of your questions, let me know if I can help though.
    Neil
    Khufu's Avatar
    West coast of Scotland
    5,693
    Does anybody know offhand the repair wire size for the cruise control retrofit? Just got my cowl & stalk off of ebay today but being a 2003 model I will need the wire too.
    Waffoo's Avatar
    Dec 2009
    Fareham, Hampshire
    Cruise Control to 09 A3 Cabrio
    As I am both lazy and ham fisted I got Hazzy Dayz to fit my cruise control. A word of warning, though - i've got the 1.6 tdi cabrio and it appears that the VCDS software hasn't caught up yet. Andy from HD came down from Hemel Hempstead to Portsmouth to fit the hardware (looked a bit fiddly IMHO - especially considering it was a new car) but in spite of having the latest VCDS software (downloaded from Ross Tech there and then) he couldn't activate it. He had to go away and Gareth come back 10 days later (yesterday) with an official-looking touch screen computer and wireless bus connector. Took 20 mins or so to do that bit. They didn't charge for the second visit and came down especially to do it so have no complaints about their aftercare!
    Moral of the story is make sure you reiterate exactly what model of car you have, and be wary if you are doing it yourself using VAG-COM / VCDS on the 1.6tdi at the moment (other engines should be fine) Gareth said the software is from the states and usually lags European cars, as the 1.6tdi is a relatively new engine - it will still change some functions, just not all. Update expected in January, apparently.
    Hope that helps your decision-making
    A3 Sport Cabriolet 1.6 TDi | Garnet Red Pearl | Luxor Beige Leather | BOSE | iPod Connection | 17" 10 Spoke V Design Alloys | Fitted by VWCruise.com: Cruise Control
