Badger5Sky Insurance
    Jun 2009
    22
    Question ET52 9J x 19" - What Tyre Size is Best ? ?
    Managed to find some OEM alloys that were too good to miss out on.
    They are not ideal as they are 9" wide and the car needs to be driveable as a daily.
    6 - 8mm spacers will have to be fitted to the front to clear the struts, maybe the same at the back to even things out.
    There are some 235/35/19 available for a good price, and I believe they will be safe to fit to a 9J wheel but I'm concerned they will rub. 225's will give better clearance but will they go on a 9" wheel?
    Are 225's safe to fit to 9" wheels and will they grip the road as well when stretched?
    Am prepared to remove the odd screw and a little plastic to eliminate rubbing and will be using Eibach Sportline Springs.
    The tyres that are on the wheels are 265's but they were 255's when the wheels left the showroom on the car.
    My main question is how narrow can you go on 9" wheels and will the tyres perform as well and be safe?
    A3simon's Avatar
    Nov 2006
    Aberdeen
    980
    i ran 215/35/19s on my 9" wheels with no probs but you will need 10mm spacers to clear the struts front and back
    2009 Suzuki GSXR1000K9 SE in White
    2012 Triumph Speed Triple R in Black
    2012 RS3 in Racing Mica Blue
    2012 A1 TFSI in Misano red (shared with mum)
    Jun 2009
    22
    I didnt realise you could go down to a 215 on a 9" wheel. I imagine there would be no clearance problems with this tyre size. Did it handle ok? I once had 215's on a 8.5J and it didnt handle well with toyo T1R's. Didnt try them with standard width wheels though so there is no direct comparison
    Oct 2008
    Telford
    2,488
    Yeah they go on but they stretch a bit, not healthy for a daily driver IMO
    B6 1.8T Avant s line gmbh
    Jun 2009
    22
    Love the look of the stretch but its not my intention. Am trying to find the most practical solution here. Fattest tyre without rubbing basically.
    Thanks for replies guys, I can try the 235's for the cost of fitting them for now so will go down that road and if there are problems am just going to have to go narrower.
    Thanks again, will post pics when the wheels are on
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,133
    10mm spacer and a 225. I had 215s on a 9, and mine was a daily driver, ride wasn't that bad, but you can't really press it around corners. So 225s if you want to retain abit of handling.
