Chris NottVolks Autos
Results 1 to 8 of 8
Thread: LUK OR SACHS
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,969
    LUK OR SACHS
    Which clutch flywheel is the better of the 2 the luk or sachs and whats the difference?
    Dealers say there not interchangeable,?????????
    Full leather/19"wheels/cruise/
    Iggu's Avatar
    May 2008
    Here
    1,224
    Audi OEM dual mass flywheel is the one to go for - with a Sachs Racing upgraded clutch.
    Does this answer your question ?
    Phantom Black S3, RNS-E with SDS Hack , BOSE, Sunroof, iPod, ITG CAI, Forge DV, Milltek TBE, Revo Stage 2+, Autotech HPFP, Sachs clutch, Lamin-X, BBS Pescaras, H&R springs, H&R ARBs, NGK Iridium Plugs, Vagcom.
    vw754's Avatar
    Nov 2006
    U.K
    1,969
    not really,i will buy from the dealers anyway,but dealers say strip box and let us know if its luk or sachs clutch/flywheel,im buying both from them,someone said sachs was better,so i was going to buy sachs and dealers said there not interchangeable if you have luk replace with same.
    tdi-man's Avatar
    Jul 2009
    1,609
    i had luk but replaced with sachs
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,322
    Quote Originally Posted by Iggu View Post
    Exactly the same here....much down to your advice!
    The stock item just doesn't last,especially with increased power and torque.
    vw754's Avatar
    Nov 2006
    U.K
    1,969
    Quote Originally Posted by tdi-man View Post
    Is sachs better than luk? i heard sachs is german and luk.....dont know.
    Also what is your engine code and do you find better drive?
    Feb 2009
    60
    I beleive Iggu has the Sachs item fitted and posted as thread on here a while ago.
    Mine is being fitted on the 22nd so I'll post some thoughts afterwards.
    vw754's Avatar
    Nov 2006
    U.K
    1,969
    robern 2 ,thanks let me know and are you changing from luk to sachs or vice versa?
