AH FabricationsJMB Retrofits
    May 2009
    yorkshire
    13
    1.9tdi air intake / induction noise
    hi all ,
    dont suppose anyone has a picture / schematic view of the induction system for a 2005 1.9 tdi bkc engine by any chance , ive got a booming noise on acceleration and was wondering where all the joints are and which has orings etc before i start to strip it down to check hoses etc
    cheers mark
    A3 sport 1.9tdi 2005 '55' ebony pearl
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,129
    Middy, do you wanna upgrade to 08 S-Line rear bumper? If so I'm selling it in the classifeids.
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    HTH
    q To turbocharger2 - Air mass meter -G70-q Removing and installing → Chapter3 - O-ringq Renew if damaged4 - 8 Nm5 - Air cleaner housing (top section)q Clean out salt deposits, dirt and leaves, etc.6 - 8 Nm7 - Vacuum hoseq To solenoid valve block8 - Air filter elementq Always use genuine part for air filter elementq Observe change intervals → Booklet808q Removing and installing → Chapter9 - Air ductq To lock carrierq Clean out dirt, leaves and salt deposits10 - Air cleaner housing (bottom section)q Clean out dirt, leaves and salt depositsq Blow out water drain (small hole in bottom section of air cleaner housing) with compressed air11 - 10 Nm
    May 2009
    yorkshire
    13
    cheers paddy ,dont suppose you have any info on turbo - intercooler hoses do you cheers
    May 2009
    yorkshire
    13
    the wife aint concerned about the back end cheers N8 , she'll scrape any bumper which is on regardless lol
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    Is this what you need ?
    2 - Bracketq Note installation position3 - Charge air coolerq Removing and installing → Chapter4 - Air hoseq Must be free of oil and grease when installing.5 - 8 Nm6 - To turbocharger7 - Air pipeq Must be free of oil and grease when installing.8 - To intake manifold flap motor -V157-9 - Vacuum reservoir10 - 15 Nm11 - 8 Nm12 - O-ringq Renew13 - Charge air pressure sender -G31-/intake air temperature sender -G42-14 - 3 Nm
