Rear SB window wet
fizz
NULL
Hi guys
I've replaced the weather strip on the rear drivers side door as when winding the window down and then back up the window is wet on the inside, however I still have the problem. Has anyone else had this problem?
Does the window glass go fully down?
If they do go down fully then its simple then, the internal & external seals are touching & the external is wet so it makes the internal seal wet, thus when going up the glass gets wet from internal seal imho
