AH FabricationsVolks Autos
    Phil_T's Avatar
    Revo Stage 2+ Audi S3
    Oct 2009
    236
    Forge Dv, Fitting On Facelift S3??
    I havent got the tools to fit it & take off the old one so went down to Halfolds looking for 5mm allen wrench or allen socket with extension, 3mm allen wrench & 1/8 inch allen wrench as per forge instructions but all I could see where torx or star attachments & none of these were in sizes there where by code like TX20 etc?
    Can anyone tell me what I need as looking under the bonnet then going back in they looked like star keys not torx but like I said there were not in sizes but code & number.
    Revo Stage 2+ - Miltek Non Res Turbo Back Exhaust - Evoms Intake - Autotech Fuel
    Pump - Forge DV - Sachs Clutch - BSH Engine/Gearbox Mounts - BSH PCV Mod - RS4
    FPR Valve - Airlift Performance Struts With Adjustable Top Mounts & Droplinks with Accuair Management - H & R Anti Roll Bars - 42 Draft Designs Shifter Bushes - BBS E28 Magnesium Motorsport Wheels - Piano
    Black Optics Grill & Fogs - Piano Black Door Mirrors - Carbon Fibre Front Splitter & Rear Diffuser
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    The bolts holding the DV in are torx bolts yep and they're coded by a T then a number. I don't know which one you need but it's worth buying a set as most bolts on your car are torx and they'll come in handy in the future.
    EDIT: Apparently they can also be coded with a TS## or TX##. The numbers will be the same sizes though and that's the important bit (bit! Get it?! ).
    8P2 S3
    Phil_T's Avatar
    Oct 2009
    236
    Quote Originally Posted by Staz View Post
    Hmm they dont look like torx as they aint as many little points, they look like a star bolt & if I need a 3mm & 5mm TS or TX 5 & 3 is 100% too small
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    There's no such thing as a star bolt really, it's just the wrong name used for torx bits. It's definitely torx anyway as I did mine only a few weeks ago.
    The numbers are explained nicely in here:
    http://www.toolspot.co.uk/category/t...s-screwdrivers
    8P2 S3
