AH FabricationsChris Nott
    S3 Owner
    Sep 2009
    Midlands
    123
    Bose Subwoofer - location & adjustment?
    Hi all,
    Can anyone tell me where the Bose amp + sub is located on my new S3, also are there any adjustments available i.e bass levels etc as I have looked through the menus on the head unit (Symphony) and there is only the standard menus for Bass, Middle and Treble
    Thanks for any help
    AuldReekie's Avatar
    Feb 2009
    UK
    766
    It is in the boot behind the N/S panel and you can't adjust the settings any more than from the head unit adjustments.
    Search for 'Andymac' the resident audiophile/expert who has made plenty of posts on the Bose system; he even does his own after market uprade solution - should you so desire.
    S3 Owner
    Sep 2009
    Midlands
    123
    Thanks for the info, I will look Andymac up and check his posts.
    AuldReekie's Avatar
    Feb 2009
    UK
    766
    This is his main Stealth Sub thread mate:
    AndyMac Stealth Sub for 8P completed
    S3 Owner
    Sep 2009
    Midlands
    123
    Thanks pal.
    RWD sucks!
    Dec 2007
    175
    If you want something cheap and simple (but not very space worthy) I added an infinity basslink 10 inch powered sub, conected to the Bose OEM sub. Sounds great! But it takes a bit of trunk space.
