Monster MotorsportEM Tuning
Results 1 to 10 of 10
    KRL
    KRL's Avatar
    Jul 2007
    523
    BSH True Seal Intake Installation DIY for K04 Cars
    As all the parts for my BSH True Seal Intake arrived last week I decided to install it at the weekend.
    For cars with a K03 turbo or cars using the BSH DV relocation the intake can be installed out of the box. However if you are running an OEM K04 for car like the S3/ED30/K1/Pirrelli then the kit requires a little adaptation for the install so I will detail this as well as the normal intake installation.
    BSH's instruction for the intake can be found online here:
    http://www.bshspeedshop.com/instruct...eal_intake.pdf
    I have referenced these instructions throughout this DIY adding my own comments and pictures.
    Here is a list of what the intake comes with:
    Parts
    Intake Pipe (x1)
    Airbox (x1)
    Bolt and Washer (x1)
    Rubber Trim lock(x3)
    MAF Screws (x2)
    DV Port Blockoff (x1)
    Clamp Kit (3 clamps)
    Silicone Coupler (x1)
    BSH Air Filter (x1)
    Here is a list of the tools you will need:
    Tools
    3/32 Allen Wrench
    T15& T20 Torx
    Flat Head Screw Driver
    Socket Wrench
    6mm & 10mm Socket
    Hose Clamp Pliers or Channel Locks
    In addition to these you will also need the following if installing the intake on a K04 car:
    Parts
    38mm (1.5) to 25mm (1) 90 degree Silicone Reducer
    25mm (1") Aluminium Hose Joiner
    Clamps (x3)
    These extra parts will come to a total of about 15.
    Installation
    1. Unplug the MAF:
    2. Undo the two silver clamps that hold the accordion turbo inlet pipe to the MAF section of the
    engine cover. This can be done by hand, if the clamps give you trouble a flat head screw driver will also
    work.
    3. Now to the front of the engine. Remove the two T15 Torx screws that hold the accordion hose
    that is connected to the engine cover and to the factory inlet duct. There is one screw on either side of the
    duct.
    4. Remove the engine cover. This is tricky to do for the first time however there are many DIYs detailing how to do it.
    5. Remove the clamp holding the accordion hose to the turbo on the back of the engine. Use your
    hose clamp pliers to do this. Remove this hose. There is a rubber grommet inside of this hose, make sure
    it comes off with hose. If not you can remove it by hand.
    This step is tricky and would be easiest if done by two people one to hold the pliers and the other to remove the accordion hose. It is possible to do yourself (as I did) but will take time and patience
    On the OEM K04 you will now need to unclamp the dv port hose from the turb inlet.
    6. Remove the factory fresh air duct from the front of the car. This is done by removing the two T15
    torx screws holding it in place. With the screws removed the duct will come out very easily. My top tip here is that as you are looking at the car from the front remove the left hand screw first:
    Followed by the right hand screw and once the right hand screw is loose leave the torx driver pushed into the screw and remove the airduct. This way you should not loose the screw
    7. Install the rubber lining on the top of the airbox and mount the BSH airbox to the front of the car.
    The bolt hole in the box will line up with the threaded eye on the battery box. Use the supplied bolt and
    washer to hold it in place. Use your 10mm socket to tighten the bolt down. If the rubber lining pops up, pinch the base of it with a set of pliers. There are metal teeth inside of the lining that will bind the lining to the box.
    In this pic you can see that the tray is actually capturing more air from the centre of the grill than the OEM setup does as well.
    8. Place the supplied silicone coupler on the turbo inlet. Make sure the coupler is on properly. Use
    the 50-70mm clamp on the bottom of the coupler to hold it in place.
    Make sure the silicone coupler is pushed right down and that the clamp is tightly attached.
    9. Place the 60-80mm clamp loosely over the top of the coupler. I found it best to tighten this clamp just a little so it gripped the top of the coupler otherwise it can fall to the bottom of the coupler.
    10. Slide the BSH intake pipe into the engine bay and slide it into the coupler. Then put on the filter. With the filter on you will want to position the intake pipe so that the front section is locked into the airbox and so that the bend over the brake fluid reservoir does not touch the reservoir or any of the surrounding lines.
    Again here make sure you push the filter down nice and tightly into the coupler.
    11. With the intake in position tighten the clamps on the silicone coupler and the air filter.
    12. Install the 90 degree silicone reducer onto the DV port of the intake tube (extra instructions for K04 cars).
    The True Seal Intake comes with 38mm port for the DV however the OEM K04 cars use a 25mm dv port as standard. Therefore to make the BSH intake compatible with an OEM K04 setup we need to use a 90 degree silcone reducer to bring the port size down from 38mm to 25mm.
    In the S3 space is very tight so first of all I had to move the sensor plug on the brake reservoir to the opposite side This can be done by loosening the cap onto top of the reservoir and then spinning the sensor round to the left hand and then re tightening (note you may need to pull the intake tubing out to do this):
    Before
    After
    Depending on how close to your break reservoir the port is you may need to cut away some of hose on the 38mm end of the silicone reducer. I needed to trim roughly 1 inch off it.
    Now you can slide the 90 degree silicone reducer onto the intake tube DV port.
    Next you need to install the 25mm aluminium joiner into the 25mm end of the silicone reducer and mate it to the OEM hose.
    Now simply clamp down the two ends of the aluminium joiner and the 38mm end of the silcone reducer.
    13. Remove the MAF sensor from the factory engine cover using a T20 Torx. Install it into the BSH
    intake pipe using the supplied screws and a 3/32 allen wrench. Plug the sensor back in.
    Top Tip remember to use the supplied screws from BSH and not the factory ones! The factory ones have a different thread to the BSH so could ruin thread on the BSH MAF holder! I started to use the factory screws and luckily realised before it was too late
    Here is a pic of the completed installation. Personally I feel the kit has a high quality finish and suites the engine bay really well.
    I will post up a product review in due course after I have had some time to get used to the intake and and make a judgement on how it is performing.
    Ice Silver S3 + every single option + REVO + BSH Street Can + Forge Twintake + Autotech
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Nice write up!
    Looks very much like the Evoms. Are the two companies linked?
    8P2 S3
    david_phillips95's Avatar
    Nov 2008
    538
    Looks pretty good, how much do these sell for? Would have been better if the dv port was the right diameter, using reducers and multiple clamps makes it look untidy and bodged IMO.
    Davie
    KRL
    KRL's Avatar
    Jul 2007
    523
    Quote Originally Posted by Staz View Post
    Nice write up!
    No they are not linked although both intakes make a very similar sound from what I've heard on youtube.
    KRL
    KRL's Avatar
    Jul 2007
    523
    Quote Originally Posted by david_phillips95 View Post
    Davie
    You can pick them up from Dubtek in the uk for 199:
    http://dubtek.co.uk/index.php?main_p...roducts_id=248
    Which is a really good deal considering that in the US they are roughly in the same bracket as an EVOMs. Also if you are a member of mk5golfgti.co.uk they will sell you the intake for 150 which is an absolute bargain
    The reason the DV port is a different size is because the intake is manufactured to be compatible with BSH's dv relocation kit. I agree about the clamps and am planning to try and find some more OEM looking ones in the future.
    Money was not really a factor for me and some of the reasons I chose the intake were:
    - It has 67mm ID piping throughout (same as stock MAF housing)
    - MAF placement is the same as stock
    - Short intake pipe meaning the air has less bends to negotiate and not as far to travel which results in better throttle response.
    - Sealed RAM style intake with the true seal box using the OEM position
    - Integrated bung for remotely loacated DV (Dubtek will provide people with a silcone reducer for this to fit the OEM DV hoses)
    - Great results and review from testing with it in the US where it has outperformed most other intakes.
    Initial impressions are very good although obviously the proof will be in the pudding which I will report in due course.
    Spin140's Avatar
    Mar 2005
    Derbyshire, England
    2,013
    The heat shielding looks better than the evoms or vf engineering equivalent but would agree the majority of us would`want a simple plug and play with all parts included, good value though and a great review
    Wife - 12 BMW 320D 181 bhp, 8 Speed Auto, Melbourne Red, Heated Leather, privacy.
    10 S3 SB, Phantom, Buckets,Int light Pack, Privacy. (Sold)
    Golf GTi MK6 - Revo stage 2, ITG, Milltek Race TBE, AP Racing 4 pot BBK - Sold.
    10 S3 SB, Phantom, Buckets,Int light Pack, Privacy,Nav, Park sensors, 6 disc, Revo Stage 1, ITG Enclosed Intake - Sold
    BMW M135i F20 - Bloody good straight from the box !
    "Fast Cars are Safer...."
    Nov 2008
    538
    I never noticed before but i see you dont have a heatshield fitted above your turbo, i ran my evoms for a while without one but the heatsoak was unreal so fitted it as soon as possible. Is there a heatshield available for this kit? next time you have been for a drive have a feel of the intake pipe situated above the turbo area and you will see what i mean.
    KRL
    KRL's Avatar
    Jul 2007
    523
    So far I have not had any problems with heatsoak. I have been testing how warm the intake pipe is after various journeys by the very scientific method of touching it with my hand. It is actually cold to the touch at the intake end and when you move closer to the turbo it warms up a little but is not anywhere near what I would call hot.
    Maybe one reason that it might be cooler than the EVOMs is that it is using the factory air feed at the front of the bonnet so it is directly exposed to cooler air?
    Nov 2008
    538
    With it being winter at the moment under bonnet temps are going to be a good bit lower than normal with all the cool air passing through. When i first fitted my evoms it was summer time, you may find that as the weather gets warmer spring/summer that the section of intake above the turbo is roasting. I would keep an eye on it when we start gettin better weather.
    Davie
    KRL
    KRL's Avatar
    Jul 2007
    523
    Thanks mate, I'll definitely keep an eye on it the warmer months.
