Results 1 to 7 of 7
Thread: Spark plugs??
    Audi S3 8P
    Aberdeen
    14
    Spark plugs??
    Hi
    I am running a stnd S3 8P and i am wanting to change out the spark-plugs but keep gettin conflicting opinions of what to fit!!
    Any views on the better plugs to go with ?!
    Mar 2009
    82
    if it's a standard S3 use the standard plugs, cannot see any advantage in anything other. I use Bosch F5DP0R in mine as it is remapped
    S3 Sportback; DSG, MRC, ITG.
    Audi S3 8P
    Aberdeen
    14
    Thanks!!
    Hi
    Thanks for that , do you know what the standard plugs are??
    Cheers!
    Iggu's Avatar
    May 2008
    Here
    1,224
    Use NGK Iridium plugs - there are loads of threads on here about the benefits they bring. Search around a bit.
    Phantom Black S3, RNS-E with SDS Hack , BOSE, Sunroof, iPod, ITG CAI, Forge DV, Milltek TBE, Revo Stage 2+, Autotech HPFP, Sachs clutch, Lamin-X, BBS Pescaras, H&R springs, H&R ARBs, NGK Iridium Plugs, Vagcom.
    Recruit
    Jun 2006
    31
    Denso Iridium VK20Y, vagtech recommended, installed on many TTS's. told no need to alter gap even with remap.
    TTS STRONIC: IBIS WHITE | ACOUSTIC PARKING | BOSE
    "PREVIOUS: A3/2.0T/S-TRONIC/REVO Stage 1/VAGCOM/RETRO FIT RNS-E, ALU PEDALS/INT LEDS"
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,362
    Still running the standard plugs here,with Stage 2+,and no problems.
    We did try the Iridiums in an effort to cure a misfire,but the solution was another problem altogether!
