EM TuningSky Insurance
Results 1 to 23 of 23
    clem2192's Avatar
    Sutton, Surrey
    173
    Condensation on interior windows - Air Con fault?
    Guys/Gals,
    Since we have had the cold snap in the weather I have found my interior windows are getting condensation on them after a short drive.
    After a 10min drive and then returning to drive home about 3.5 hours later there is condensation on the windows.
    I have tried a number of settings (Econ on / off, Air Con on/off, recirc and climate control on/off) but the problem still seems to exist.
    Is this a problem with the air con system or am I just being a div and not using the correct settings?
    There are no wet patches in the passenger footwell either
    Nice One
    Ryan
    TAC
    TAC's Avatar
    3.2 V6 Burble... hmmmmmmm
    Oct 2009
    302
    I have exactally the same, I don't believe it to be a fault with the air con though I believe that on short journeys the moisture just does not get removed fully by the system as the car will not have run up to temperature and will just re-circulate the mositure. Most people I work with who drive in around 10 minutes all have this happen no matter what make of car they have.
    Hope this puts you mind at rest.
    Current - A3 3.2 DSG S-Line
    Gone but not forgotten Honda S2000 GT K&N FPIK (F***ing lairy in the wet but so so much fun...)- Golf MK3 GTI 16v -Mondeo V6 24v
    FOR SALE - Indicator stalk and lower steering wheel cowling
    A3 3DR pair of rear lights in A1 condition from my 06 A3
    clem2192's Avatar
    Sutton, Surrey
    173
    Quote Originally Posted by TAC View Post
    Thanks, this does help.....so should I just leave the climate on 'Auto' around 22.0 degrees or should I be using some other settings??
    TAC
    TAC's Avatar
    Oct 2009
    302
    Quote Originally Posted by clem2192 View Post
    I tend to stick the window demist option on and wack the temp up full, recently I have been going out and starting her up 5-10 minutes beofe driving to give it a good chance to demist properly and then if its a sunny day (few and far between un the UK I know) parking in the sunlight as the raidiant heat from this will also help.
    Another fix is to go for a long drive 40 minutes + and that should cure it for a few days..
    clem2192's Avatar
    Sutton, Surrey
    173
    Thanks, will give that a go.....may just leave her running for a bit with the temperature on full and air con on to see if I can get rid of some of the moisture!
    On another topic, do you find it difficult to change smoothly between 1st & 2nd??
    TAC
    TAC's Avatar
    Oct 2009
    302
    No I have no problems however mine is a DSG so is seamles I am assuming you have a manual?
    clem2192's Avatar
    Sutton, Surrey
    173
    Yes, I have a manual! Thanks anyway!!
    Khufu's Avatar
    West coast of Scotland
    5,693
    If its a 10 min drive you should be cycling LOL
    Oct 2008
    Telford
    2,484
    Quote Originally Posted by Khufu View Post
    My works a 5 min drive! thats why i need a diesel!
    on the subject of the AC though, TDi's warm up slow so i'm not suprised this is an issue if yours is a derv.
    B6 1.8T Avant s line gmbh
    Dec 2008
    249
    I had a similar issue a few weeks ago and it turned out my rear passenger side door weather strip was faulty and was letting a lot of water into the door which was draining ok, however was causing condensation.
    Apr 2009
    Florida (previously Liverpool)
    655
    Condensation is caused by:
    * Having the recirculation on.
    * Having the Air-Conditioning off.
    * Having COLD air directed at the glass instead of into the car.
    Any of the above -individually or in combination- will increase the tendency for moist air to condense.
    Keith
    May 2009
    Birmingham
    95
    One thing to note is to make sure the inside of the windows are cleaned regularly...this helps to prevent build up of condensation believe it or not and helps to prevent the inside of the windows misting up too easily...
    Collected 14 July - 2009 MY10 A3 1.9TDIe Sport 3dr in Brilliant Black
    Factory options: Cruise Control, Debadged, Chrome Exhaust tips
    Mods: CC Tuning remap.
    Spin140's Avatar
    Mar 2005
    Derbyshire, England
    2,013
    Good tip and true.
    I was having issues with mine despite it having had full valet at the dealers, I cleaned the windows myself with the cream from autoglym and its been much better since plus the kitchen roll was black with filth, they can look clean yet be full of moisture and dirt.
    Wife - 12 BMW 320D 181 bhp, 8 Speed Auto, Melbourne Red, Heated Leather, privacy.
    10 S3 SB, Phantom, Buckets,Int light Pack, Privacy. (Sold)
    Golf GTi MK6 - Revo stage 2, ITG, Milltek Race TBE, AP Racing 4 pot BBK - Sold.
    10 S3 SB, Phantom, Buckets,Int light Pack, Privacy,Nav, Park sensors, 6 disc, Revo Stage 1, ITG Enclosed Intake - Sold
    BMW M135i F20 - Bloody good straight from the box !
    "Fast Cars are Safer...."
    jameo84's Avatar
    Sep 2009
    east kilbride
    123
    iv not got aircon and have the same problem, try rain X anti fog, i got some from tesco for under 6 and its worked a treat
    26,750
    Interesting, rain X huh, will check it out.
    May 2009
    Birmingham
    95
    yeah rain-x is used a lot by the detailing guys on the exterior glass and if they use it....
    never heard of rain-x anti fog but if the stuff for exterior glass works...
    26,750
    You having trouble finishing your sentences or need a prompter, lol
    May 2009
    Birmingham
    95
    haha, one of my many bad habits!!
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    Try a very snall anount of washing up liquid polished on to the inside of the window...not the screen. thats what bikers use to stop visors on helmets steaming up. try it on one window so you can check that its working against the others.
    beanoir's Avatar
    Sharpest Tongue in the West
    Jan 2007
    51 Degrees North
    2,173
    Quote Originally Posted by paddy View Post
    I had a problem once with condensation, I know this sounds obvious and maybe a bit stupid, but I was keeping my swimming kit in the boot on an evening and not removing it until the following night after work, I was getting terrible condensation in the mornings and took the aircon ages to clear it.
    As I say, I may just be a muppet, but it was causing a similar problem, anything wet in the car will. As will a leak in the boot or door seals.
    Porsche Cayman S |Jeep Grand Cherokee|1988 Ford Fiesta XR2
    www.essexdriversclub.com
    dan1973's Avatar
    OCD clean
    Oct 2009
    301
    Right here goes, i suffered condensation up until recently. Being a detailer my self i used Rain x anti fog, until i was told about a cheap product on dw called 'Astonish Glass cleaner anti fog' it's 99p from wilkinsons. A bargain and it works too. I did half my front screen in it and you could see visibly the difference. Great stuff and at 99p a bargain.
    99 Audi a3 tdi sold....
    56 Audi a3 2.0 tdi sline dsg sportback sold
    06 Audi a3 2.0 tdi sport sold
    2001 Audi a3 1.8 20v turbo sport ( new project draining my wallet )
    Khufu's Avatar
    5,693
    I prefer pinlock LOL
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    Yea...Bob heath visor spray if you like spending money
