AH FabricationsVolks Autos
Results 1 to 16 of 16
    A4 Cabriolet 1.8T Owner
    Oct 2009
    Wisbech
    86
    Audi A3 ESP light on permanently
    Hi, just ran a check with my Launch X431, the ABS module is throwing these fault codes:
    00810 Brake Pressure Senders 1/2
    00778 Steering Angle Sender - G85
    01423 Sensor for Lateral Acceleration G200
    Anyone have any idea where to start!?
    Daniel
    DJM Auto
    Daniel.
    27,099
    Have you fitted a new steering wheel recently or at all?
    If so these need calibrating properly which would then get rid of the errors & light.
    Oct 2009
    Wisbech
    86
    Nope same steering wheel.
    Daniel.
    27,099
    Those errors all point towards something has been done to the steering module/area, but anyway they need calibrating usually with vas at audi or vagcom if you have it, if you dont then either ask member from link in my sig to do or buy the genuine kut from me.
    Oct 2009
    Wisbech
    86
    Can it be done with my Launch X431
    Daniel.
    27,099
    You would need to check with the uk support office mate
    http://www.x431ltd.co.uk/website/contact.html
    As I use vagcom only except on the odd occassion audi let me play with a vas unit
    Oct 2009
    Wisbech
    86
    Well i got adaption and coding for modules
    just need to know what channel(s) i need to do
    Daniel.
    Oct 2009
    Wisbech
    86
    Well Audi said that the fault code 00810 means a new ABS pump (1,200) and the rest would need to be coded to clear them.
    I would like to just try coding, is it basic settings then channel 04 ?
    Daniel.
    Daniel.
    27,099
    Oct 2009
    Wisbech
    86
    strange, the login code 40168 comes up Login failed.
    Weird.. now what to do..
    Daniel.
    27,099
    Hold on a minute, what car you doing this on as you show as A4 cab but in the 8P section?
    http://wiki.ross-tech.com/index.php/...et_%288E/8H%29
    Oct 2009
    Wisbech
    86
    its a customers car, 2003 Audi A3 2.0 FSI (new shape)
    Daniel.
    27,099
    aha bistro, all becomes clear now, personally dude I would use vagcom for all vag cars, not because I sell the kit, but because it works flawlessly, try discon battery for 5 mins then on again & retest also speak to x431 support, sounds like something out of star wars, lol, the 40168 has worked for me no problem everytime.
    Mar 2010
    14
    3 Faults Found:
    00810 - Sensor 1/2 for Brake Pressure
    005 - No or Incorrect Basic Setting / Adaptation
    01423 - Lateral Acceleration Sensor (G200)
    00778 - Steering Angle Sensor (G85)
    I have a VAG COM interface and i am using VCDS 11.2.0
    how can i recalibrate everything ?
    27,099
    Genuine cable?
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,609
    Sounds like a faulty Yaw sensor to me. Its located under passenger seat and under the carpet in the A3, next to the cross-member. Unfortunately not a cheap part.. £500ish from dealers.
    Website | Facebook | Audi TT 2.0TDI 170 Quattro
