Badger5Chris Nott
    Jun 2009
    maesteg
    Boot opening??????
    hi all,
    my boot keeps saying its open on the dash,but when i get out and check it its closed and because of this the alarm isnt set when i lock the central locking..any ideas???????
    Aberdeen
    I had a similar problem with my bonnet showing as open all the time, just disconnected the sensor. It didn't cause an issue with the alarm though. Might be an unrelated coincidence ?
    mitch78's Avatar
    Mar 2007
    noun: a particular place or position
    2,723
    It should have done, as the alarm doesn't arm if anything is seen as being open.
    Ex 8L S3 driver
    also A3, 320, Golf, Clio, Astra, Focus, Mondeo, Laguna, Escort, Calibra, 220, others and now back to a Focus...
    27,028
    Quote Originally Posted by dalecoles2005 View Post
    hi all,
    Cant recall where the boot sensor is, might be in the lock itself as a microswitch just as the door locks have, in which case, could be this thats playing up, spray the hooked lock with wd40 & manually push it in & then release with the boot handle/catch, do about 10 times then test it, cant check atm given time but working on car tomorrow so will check then.
    Quote Originally Posted by storm0906 View Post
    Sensor disconnected would not arm alarm, will throw error.
    Quote Originally Posted by mitch78 View Post
    Yeap I'd concur with Mitch 100%, if bonnet sensor isnt pushed etc then alarm wont arm & indicators wont flash in a normal state
    wesley's Avatar
    Giac Extreme+!! Lovin it
    Feb 2007
    Manchester
    323
    had exactly the same prob on the mrs 2.0 tdi, the microswitch is built into the lock, A common fault on the rear wiper on A3's is that they occur a leak and when the boot is shut this leak drips right onto the wire on the microswitch causing it to malfunction. I took the plastic cover off the inside of the boot and removed the wire to the boot lock to find it wet inside, dried this out and hey presto fully working again. Then replaced my faulty wiper motor to stop the leak.
    07 Suzuka Grey S3, Giac Extreme plus map, Autotech HPFP, VF Engineering CAI, 18" black rims,factory tints,fbmfsw,Mk 2 RNS-E,CH-LH lights.puddle lights,Bose,Shark fin, Lamin x lights & Fogs.Full TBE miltek, 09 White DIS,Buckets,LED conversion,TPMS.
    27,028
    The boot lock seems to have a plastic covering on the latch/hook, mine seems to have become perished minimally, so sometimes it gets caught & takes a slight tug to open boot, so trimmed it down & wd'd & opened better, but fear replacement lock needed, works for now
